Garrett turbo reliability - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by D-Man, this thread has received 6 replies and been viewed 863 times.
post #1 of 7 (permalink) Old 01-17-2007, 03:46 PM Thread Starter
I have decided to buy a Garrett turbo but, I have heard talk about some issues. First of all, surge. I won't be towing anything large but will be getting programs up to 120 hp. Do I need to worry?
Second, oil leaking/burning issues. This truck is going to be my only mode of transport in the winter so I need reliability.
Are these two issues just isolated instances that I have heard about?
Please weigh in Thanks D man
D-Man is offline
post #2 of 7 (permalink) Old 01-17-2007, 04:00 PM
CSIPSD's Avatar
1. Surge... Mine was BAD, some do it some don't. I don't know why some trucks surge worse then others but mine did bad. Empty, loaded, pulling it surged. Now after garret had it for a few MONTHS... I have a new one that just arrived at my house that has had some added porting done to it. I have been told this will stop the surge issues. I will be swapping turbos again for another try this weekend or next.
2. Oil leaks/ Oil burning... I feel this is 100% related to the CCV mod. Of the three trucks I have read about having oil issues (myself included) ALL ( READ ALL) have had some kind of CCV vent mod to a filter or into the exhaust. The oil seals on the BB must be very thin to allow the quick spool and any back pressure in the system... well the turbos oil seals are the weakest link. When I swapped to the TN unit after removing the Garret... guess what? My oil leak issues were still there. I removed the filter from my ccv mod and the oil leak stopped!
3. Here is my take at this point. The Garret can surge, will it? Maybe, maybe not. The TN unit DOES NOT SURGE. The Garret spools FAST! That's fun. The TN unit spools (with the 1.00ar exhaust housing) a little slow. Not bad, about on par with the stocker. The TN unit with the .84 housing spools quick, about as fast as the Garret. I still want to give the Garret another chance...
4. Garret is a throw away turbo... Once it is bad, throw it in the trash. It will cost about $700-900 to rebuild a Garret. A turbonetics can be rebuilt for about $100...
5. Garret warranty... SUCKS! I waited 3 MONTHS to get mine back
TN unit... well I have read about BOLTS going thru them and TN warrantied them...
Poster steps down off podium:Thumbup:
CSIPSD is offline
post #3 of 7 (permalink) Old 01-17-2007, 05:14 PM
Why is it throw away if you can rebuild it for 700-900?
A new ball bearing costs double that doesn't it?
gregrob is offline
post #4 of 7 (permalink) Old 01-17-2007, 05:51 PM
dzljon's Avatar
:agreed: , I personally like the TN for the cost and maintenance, i bought mine from Black Widow Diesel for $1280 plus shipping when compared to the Garrett BB set up that is around $1650 give or take alittle, i can rebuild my TN 2 times before i get the price of 1 garrett... no surging or spooling problems i pull a 10,000 lb race trailer regularly and have had more than 20,000 trouble free miles
99.5 F250, VGT 5.9 CR cummins
dzljon is offline
post #5 of 7 (permalink) Old 01-17-2007, 06:11 PM
CSIPSD's Avatar
Because after that $900 bill you still have a used turbo, with a new center section...
CSIPSD is offline
post #6 of 7 (permalink) Old 01-17-2007, 06:20 PM
Hmmm...
I just checked and I can get the ball bearing for a good price but it requires a core. Sounds like someone is adding the bb center section and wheel to stock turbos anyway???
gregrob is offline
post #7 of 7 (permalink) Old 01-17-2007, 10:00 PM Thread Starter
the turbo I am buying is slightly used, the owner claims he had no surge when it was on his 7.3 and I believe him. But, could it surge on my 7.3?
D-Man is offline
