Need Help Battery Light is on - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by imported_CWAGO, this thread has received 7 replies and been viewed 1234 times.
post #1 of 8 (permalink) Old 01-19-2007, 02:26 PM Thread Starter
I changed both batteries last night. Bought brand new ones from Advance Auto. This morning the truck starts fine. On the way to work the battery light keeps flashing.
Whats going on? Anyone have this happen?
This is on the womans 01 F-250.
Thanks
Cody
imported_CWAGO is offline
post #2 of 8 (permalink) Old 01-19-2007, 02:29 PM
Super Moderator
John_G's Avatar
Cody,
The battery light in an indication of ALTERNATOR function, not battery condition. Yup, stupid I know.
I would suspect that alternator is failing, although unusual, it happens. It could also be that the key supplied power to the alternator is too low for it to work properly, this can be caused by a bad ignition switch, corroded connection, or bad/correded fuse or fuse holder.
I vote for LIBERTY!
John_G is offline
post #3 of 8 (permalink) Old 01-19-2007, 02:48 PM Thread Starter
Thanks John,
I had to give her a jump on one battery and use a jump box on the other yesterday when she got off work. I went ahead and bought the batteries anyways, they were the original 01's.
I will take it to Auto Zone or Advanced and get the alternator checked this afternoon.
Thanks
Cody
post #4 of 8 (permalink) Old 01-19-2007, 02:57 PM
A loose Alt connection will make the light flicker. John covered same i guess. If it tests 13V output wiggle em. May as well let the store test em since your a customer.
RacerX is offline
post #5 of 8 (permalink) Old 01-19-2007, 06:11 PM
Changed one battery last week and had this same thing happen for several days and now it hasn't happened again. Battery light would come on and then maybe flash for several minutes or just stay on continually for a while. Mysterious...yes Leaves me feeling warm and fuzzy all over...no
hopeful 6.0 is offline
post #6 of 8 (permalink) Old 01-20-2007, 02:38 AM
hey also check the power cable for the starter if it is loose be careful when you tighten it it is connected to plastic and it will break very easily.
2006 lariat fx4. Straight piped. SCT tuner.
SLAPS MEMBER
SINGLES MEMBER #125
platinum01 is offline
post #7 of 8 (permalink) Old 01-22-2007, 02:59 PM Thread Starter
thanks guys.
On the way to Auto Zone, she run the truck out of fuel . So I called one of buddys and had it towed to the house. Got up the next morning and got her started. Went to A.Z. and got a new Alternator. Got it back home and noticed the casting was wrong and wouldnt let my bolt go through the hole. Took it back and went next door to O Reilys. They matched A.Z. price. Installed the Alt in the rain: Drove it down the road and it still flashes laugh . Guess I will check the starter wire and if that dont work take it back to OReilys and have it tested.
Cody
post #8 of 8 (permalink) Old 01-23-2007, 02:45 PM Thread Starter
Well, I found out the problem with the new alternator.......... I didnt have the plug all the way on. I was messing with everything and when i touched the plug the light under the hood got brighter
thanks for all your help!!
