Water pump question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by racehauler, this thread has received 2 replies and been viewed 489 times.
post #1 of 3 (permalink) Old 01-19-2007, 08:07 PM Thread Starter
Question Water pump question
I have seen some very slight amounts of coolant coming from the weep hole of my water pump. It would be better to replace it now while I don't depend on the truck so much. Any way I found a pretty good deal on a pump. It is a new Ford part # F81Z-8501-FA or Motorcraft PW-455. The casting has number 1831005C22 on it.
The seller says it fits 1998.5 to 2003 7.3's Dont ask me why they say 98.5 but I saw the application sheet myself :shrug:
Will it fit my 96? I thought the pumps were the same from 96 to 03.
:thanks: in advance
Eric
Eric
Dually Club Member #53
racehauler is offline
post #2 of 3 (permalink) Old 01-20-2007, 02:29 AM
hey when i bought mine for my 01 the receipt said for 2000 to 2002
2006 lariat fx4. Straight piped. SCT tuner.
SLAPS MEMBER
SINGLES MEMBER #125
platinum01 is offline
post #3 of 3 (permalink) Old 01-20-2007, 03:54 AM
Ol Dirt Contractor
Lowboy's Avatar
Pumps are the same except for the thermostat housing and the heater outlet on top. Pre 99 is a short thermostat, 99 up being a longer thermostat assembly. Iíve interchanged them both ways.
On the 96 if you donít want to interchange a couple of parts itís easier to use the pre 99 unit.. But, once that weep hole starts dripping itís time to replace that pump. My wifeís 99 exploded the WP bearing about a week ago and I had to call the hook to get me home..
I was Anti-Obama before it was cool!
Leno: ĎRemember the Old Days When Obamaís Biggest Embarrassment Was Joe Biden'
Ernie Hasse+ Bill Gaither America Medley
XCR 800cc Polaris Triple with Turbo, Nitrous & RMI
96 F250 7.3 Hypermax Stage IIIís, H2 for now, Wide Open Performance long block. Spearco Intercooler 4Ē downpipe Suncoast Tranny, Terminator Oil
Newest--2015 Black VW Golf SportWagen TDI DSG Nav Roof 18" Avignon's Valentine One
Early 99 F250 SD 7.3 almost stock for now
87 Turbo Intercooled T-Bird stock
98 379 Pete 15.8L CAT 3406E 5DS Borg Warner 175963 Turbo P5 Nathan Horns Johnson Matthey 600 HP DPF 2017 CA registered emissions legal
More Milwaukee V28 Tools than Tim Allen has!
Remember, nozzle size matters at the pump
Lowboy is offline
