**help Please No Start** - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by pwrstroke99, this thread has received 6 replies and been viewed 514 times.
post #1 of 7 (permalink) Old 01-20-2007, 09:37 PM Thread Starter
well i have a problem my truck will not start up after i washed and degreased the motor it ran fine before that, then there wasnt a wait to start light so i read on here and TDS about the GPR so i changed that and still nothing but i did jump the relay from the little terminal to one of the big ones and it will start like that and the wait to start light comes on like that, so i goto the junkyard and get a PCM and still nothing so do you guys think i got a bad GPR, oh btw i checked every single fuse and relay in the truck and they are all good. please help im tried of using jumper wires to start my truck.
pwrstroke99 is offline
post #2 of 7 (permalink) Old 01-20-2007, 09:42 PM
let me get this right you put a jumper on the small terminal to the batt hot large term of the GPR and then it powers up and you can crank and start it with the key ??
if so sounds like a loss of power to the pcm when you say you checked the fuses did that include the ones in the power dist box under the hood? the fues for the GPR IPR and ecm ign power is in there and it sounds like that circuit is the one with an issue
Photos of The Beast
DOC
Docluv2577 is offline
post #3 of 7 (permalink) Old 01-20-2007, 09:53 PM Thread Starter
no i put a small jumper to the small terminal on the GPR to the large terminal on the GPR and that kicks the glow plugs on and the truck will start but if i unhook the jumper it will shut the truck off. and yes i checked those fuses too i used a test light and went through all of them and for the relays i turned the blower on and tested them all through that, i hate electrical systems.
post #4 of 7 (permalink) Old 01-20-2007, 09:56 PM
ok so basicly what you are doing is back feeding power to the pcm by using that jumper. if after starting it and you remove that wire does it quit.. and with the wire on if you turn the key off does the truck stay running
it sounds like you have a problem in the wiring from the fues in power box to the pcm/gpr/ipr.
Photos of The Beast
DOC
post #5 of 7 (permalink) Old 01-20-2007, 09:59 PM
Super Moderator
John_G's Avatar
The underhood fuse and relay panel got wet, and I would suspect the PCM relay is toasted.
I commend you for getting this far with the diagnostics, most would have quit by now and had it towed.
I vote for LIBERTY!
John_G is offline
post #6 of 7 (permalink) Old 01-20-2007, 10:07 PM Thread Starter
the pcm relay is in the under the hood distribution box right if it is i checked it i took the blower relay out and put the pcm relay in the blower spot and the blower came on so that to me would say that it works but idk this electrical b.s got me stumped
post #7 of 7 (permalink) Old 01-20-2007, 10:45 PM Thread Starter
oh and one more thing my programmer can read the codes but it cant put my truck back to stock so its stuck on the extreme tune
