ebpv problem with new exhaust installed - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by smokin dually, this thread has received 9 replies and been viewed 808 times.
post #1 of 10 (permalink) Old 01-23-2007, 03:54 AM Thread Starter
soot junkie
I am having trouble finding any info on this. I put a 5'' exhaust on a guy's 99 F350 and now the ebpv comes on when he is driving down the road. It does this as long as the fuel pedal is held at a steady position. It does this while the motor is cold or hot. I need suggestions on the problem or the fix. Please help. :shrug:
01 F350 CC Dually, DP tuner, fuel system w/Aeromotive pump, 360cc Stage III Hybrids, Stealth Big Oil, H2 Hybrid, Head Studs, Hypermax rods, balanced rotating assembly, Comp Cams valve springs and push rods, ATS trans fixed by BTS, Best 1/4 [email protected] best 1/8 [email protected]
2000 F250 6sp, Dp Tuner
Early 99 F350 2wd daily driver Dp Tuner
smokin dually is offline
post #2 of 10 (permalink) Old 01-23-2007, 03:56 AM
circle5's Avatar
Mine does that too! i just unplugged that damn thing!! i think its probaly a sensor
circle5 is offline
post #3 of 10 (permalink) Old 01-23-2007, 03:58 AM
You can wire them open if he does not use it much, but prolly a sensor. And, it is prolly not the 5", but that prolly made it more noticable.
Logan is offline
post #4 of 10 (permalink) Old 01-23-2007, 04:16 AM
CSIPSD's Avatar
His EBPS is plugged or bad, Replace or clean the tube and sensor and it will start working again.
CSIPSD is offline
post #5 of 10 (permalink) Old 01-23-2007, 10:47 AM
Does it make a shuddering sensation? My truck started shaking bad after installing a 5" exhaust, especially about 40mph at WOT. If I'm easy on the throttle it's not as bad; but what's the fun in that I'm guessing the EBPV failing would rob power as well?
Tim
Early 99 Crew Cab Long Bed Lariat 4x4 7.3L PSD Primary Horse Hauling Rig
-Stage 1 160cc Single Shot Injectors - DP Tuner F5 - 60 Tow, 80 Econo, High Idle, Stock - NVK5 PCM thanks to DP Tuner
-Home Brew fuel system with Aeroquip socketless fittings, socketless hose, and Aeromotive Regulated Return
-4" Lift 285/75R16 E Nitto Dura Grapplers - 5" MKO Aluminized Exhaust w/6" Stainless Tip - Pair of Optima Red Tops - Napa 6637 Air Intake filter - Triple Gauge A-pillar Pod w/Autometer UltraLite:Trans, EGT, Boost - CCV Mod
ndrorydr is offline
post #6 of 10 (permalink) Old 01-23-2007, 05:10 PM
Tim
Yes a closed EBPV kills power
powrstrkn' is offline
post #7 of 10 (permalink) Old 01-23-2007, 08:07 PM
imagine pulling a house thate what the EBPV closed feels like
just visiting is offline
post #8 of 10 (permalink) Old 01-23-2007, 08:40 PM
is it bad to disconnect it ?
Drrm80 is offline
post #9 of 10 (permalink) Old 01-23-2007, 08:52 PM
If you do that it won't close for cold warmup's.
If it were me I would try cleaning the EBPS /tube
post #10 of 10 (permalink) Old 01-24-2007, 05:45 AM
Yeah i un plugged mine as well actualluy i took the butterfly valve off, so i totally disregarded the EBPV, alot of the time the valve gets stuck and does not work consistantly anyways. MORE FLOW!!! :smoke
imported_whitelightning is offline
