'95 7.3 starting problems... - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by dieseldummy, this thread has received 23 replies and been viewed 1829 times.
post #1 of 24 (permalink) Old 01-24-2007, 05:33 AM Thread Starter
Sperm Donor
I've been roped into working on my brotherinlaw's PSD some how... Saturday night it ran fine, but Sunday morning he started it and it ran for a while then died. After that I wouldn't start. Today I go over to work on it and they want me to check the fuel PSI so I do... Nothing! It would barely pump a little fuel when free flowing and would build any pressure. (I thought the problem might be the CPS so I look at the tach while cranking... it registered RPM so I figured it was ok)
Off to the parts store I go. $115 later for a new Carter pump I go to work. That banjo bolt under the turbo is a real *****... Anyways, I get the old pump out and find that the plunger that rides on the camshaft stayed in the hole and doesn't go with the pump. It was broken in half for some reason. The new pump went in and we cranked the motor over to prime the fuel system... Now it makes 40+ PSI, but still no start...
While cranking it over to try and get it started I notice that the tach suddenly drops to 0 RPM's... I guess that 1yr old CPS is bad too? The SES light isn't on...
Is there anything I'm missing here? I don't usually work on PSD's so I thought I might be overlooking something simple.
Thanks,
Justin
some diesel stuff
dieseldummy is offline
post #2 of 24 (permalink) Old 01-24-2007, 05:25 PM
a bad cam sensore wont always set codes if you arent seeing rpms I would say try a cam sensor
Photos of The Beast
DOC
Docluv2577 is offline
post #3 of 24 (permalink) Old 01-24-2007, 11:20 PM Thread Starter
Sperm Donor
Yeah, I've got one on the way. Should find out later this evening if it helps.
some diesel stuff
post #4 of 24 (permalink) Old 01-25-2007, 02:59 AM Thread Starter
Sperm Donor
CPS didn't work. Still not starting... There is oil to the heads and fuel coming out of the fuel filter. What next??
some diesel stuff
post #5 of 24 (permalink) Old 01-25-2007, 03:02 AM
ok you know you have 40 psi fuel pressure thats sufficient to run you have a good cps
I let it slip before have you check glow plugs and glow plug relay ??
if that all works ...
at this time you need a scan tool to observe rpms and Inj control pressure if the scan tool doesnt read rpms you have a cps wiring issue if Inj control pressure doesnt get at least 600 psi or so you have an ICP system issue
Photos of The Beast
DOC
post #6 of 24 (permalink) Old 01-25-2007, 03:05 AM
Diesel Dog's Avatar
Are you sure you have at least 10.5 volts while cranking? Might try hooking up a set of jumpers
Diesel Dog is offline
post #7 of 24 (permalink) Old 01-25-2007, 05:43 AM Thread Starter
Sperm Donor
Yeah, it's got plenty of volts. I had it on the charger all night and used booster mode when cranking. I had the fuel filter housing to replace a hose and noticed the IPR Solenoid nut was loose... I took it the solenoid apart and cleaned it up. Put it back together and still nothing. Could the IPR be bad?
Thanks for the advice so far! As you can tell I'm a PSD novice...
some diesel stuff
post #8 of 24 (permalink) Old 01-25-2007, 07:45 AM
Check the HPOP. The oil should be within an inch from the top. Check the fuses under the hood. Sometimes the #22 fuse under the hood will blow and give a no start.
Stroker 94 is offline
post #9 of 24 (permalink) Old 01-25-2007, 03:32 PM Thread Starter
Sperm Donor
The HPOP resivoir is full and will fill and overflow with the plug out while cranking. Checked the fuses first thing and they are all good.
some diesel stuff
post #10 of 24 (permalink) Old 01-26-2007, 04:56 AM Thread Starter
Sperm Donor
Finally got a P0603... The dealer mechanic seems to think the IDM may be toast.
some diesel stuff
