7.3L Dimensions - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by nak1017, this thread has received 3 replies and been viewed 1038 times.
post #1 of 4 (permalink) Old 01-24-2007, 11:24 PM Thread Starter
7.3L Dimensions
What're the dimensions/weight of the 7.3L? I'm thinking about doing a swap into a smaller truck...
nak1017 is offline
post #2 of 4 (permalink) Old 01-25-2007, 01:14 AM
KT Performance's Avatar
I don't know the numbers to help you out, but what size truck are you wanting to go to. A buddy of mine is putting an 1160 CAT in an 87' F-150. He is modifying the frame a lot to get it done. I do like your ideal, fill us in on your plan. :Thumbup:
KT Performance is offline
post #3 of 4 (permalink) Old 01-25-2007, 04:52 AM Thread Starter
Unfortunately I think I'm a couple of years out from this... but I was thinking about relatively stock diesel in a tacoma or s10 or something. I like the idea of using a import truck just for the oddity. I figured I'd have to mod the frame, make a trans tunnel and massage the firewall a bit, but that's no biggie (that's half the fun). Atleast I'm short so I can push the engine back if I need to. I'll probably think of some other fun stuff... any ideas?
nak1017 is offline
post #4 of 4 (permalink) Old 01-26-2007, 12:41 AM
Jeff is going big with his truck, are you going to try to keep close to stock height? You could do a lowering suspension kit along with a body lift to give you more room under the hood and keep a more stock look.
