Cold weather/high idle - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by POWER STROKE 99, this thread has received 13 replies and been viewed 1489 times.
post #1 of 14 (permalink) Old 01-26-2007, 02:00 AM Thread Starter
TDG MAFIA MEMBER #71
POWER STROKE 99's Avatar
I was wondering if short trips in this cold weather that we are having (10*) is going to hurt my engine? I try to let it warm up until the coolant gauge moves but sometimes I can not wait that long. Will it hurt if the truck if it is not completly warm before I shut it down, my trip to work is only about 5 to 10 minutes depending on road conditions?
The other thing is can I make the truck idle high all the time when idling in cold weather? The reason I ask is, I recently read about wetstacking.
I would also like to change my coolant, does anyone have any sugestions?
Thanks for any info.
POWER STROKE 99 is offline
post #2 of 14 (permalink) Old 01-26-2007, 02:35 AM
Lots of people use evans coolant.
For the high idle you can't beat the ford Aux Idle Controller
As for the hurting the engine, I say no so long as you don't flog it while you're still cold. I do the same thing alot runnig back and forth between the barns and my house
powrstrkn' is offline
post #3 of 14 (permalink) Old 01-26-2007, 03:14 AM Thread Starter
Do you have to get the Aux idle controller from a Ford dealer, or can you buy it from our vendors on TDG?
post #4 of 14 (permalink) Old 01-26-2007, 06:34 AM
X2 on that idle control i am very interested
just visiting is offline
post #5 of 14 (permalink) Old 01-26-2007, 06:40 AM
CSIPSD's Avatar
Look around Ebay... they come up every now and then... You can add a chip to your truck with a high idle setting too. The Ford Axl Idle will set you back about $300 so
CSIPSD is offline
post #6 of 14 (permalink) Old 01-26-2007, 11:31 AM Thread Starter
So what you are saying is I would be ahead by buying the chip.
post #7 of 14 (permalink) Old 01-26-2007, 12:55 PM
Just get a high idle position on your new chip that is "coming soon"!!!!:Thumbup:
1994 F-250 PSD ext cab 5spd 4x4 Gutted ebpv ,Valeo smf and clutch,3 pos Tony Wildman chip!, 3-4" Dp, 4" exhaust,Tymar intake, shimmed fpr, HPX crossover, 1.0 a/r exhaust housing, vdo gauges, 279,000k
1996 F-250 PSD CC SB 4x4, 5spd, 4:10's SMF clutch, 3" dp, cats gone, gauges Tymar intake, HPX, .84 a/r exhaut housing, 6oh intercooler/GTS kit, 4pos chip by Tony Wildman!
ltfox is offline
post #8 of 14 (permalink) Old 01-26-2007, 03:14 PM
i wish i had a chip coming soon but i dont have the money, i kinda want to do turbo, injectors and chip all at once so i am not burning a chip than modding only to send the chip back out
post #9 of 14 (permalink) Old 01-26-2007, 04:07 PM
The womans truck idles high when its cold all by its self and so does the Cummins.
imported_CWAGO is offline
post #10 of 14 (permalink) Old 01-26-2007, 04:28 PM Thread Starter
Mine does idle high by its self, but only part of the time.
