Mods for Work Rig - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by brendonv, this thread has received 5 replies and been viewed 666 times.
post #1 of 6 (permalink) Old 01-29-2007, 02:40 PM Thread Starter
brendonv's Avatar
Mods for Work Rig
Hey,
I am new here.
Just bought a 1999 F350, 6 speed, DRW, with 90k.
I am an arborist and it is used as my chip truck, and I am looking for some cheap MPG raising mods.
Can anyone suggest an intake/exhaust mods for my rig, or anything else to raise MPGS/power.
THanks!
Early 1999 F350 DRW Dump, 6spd 4x4, 4" Turbo Back and DIY Intake
Early 1999 F350 SRW 8' Box, 6spd 4x4 Stock
brendonv is offline
post #2 of 6 (permalink) Old 01-30-2007, 12:49 AM
I would recommend starting with A TYMAR intake or something like that. Any good open air intake would do. Also a free flowing exhaust would help some with the mpgs. Once you do those then I would recommend a multi position chip. That way you can have different settings for loaded and unloaded. Definetally remember to get some guages in there to monitor what's going on under the hood.:smoke
DozerDoug is offline
post #3 of 6 (permalink) Old 01-30-2007, 12:50 AM
By the way nice truck. I should have added that in the first post.
post #4 of 6 (permalink) Old 01-30-2007, 01:16 AM
Smokin'
Marty's Avatar
Since it's going to be loaded about 50% of the time I'd do the following.
Tymar intake
Straight pipe current exhaust
Gauges - EGT/Boost
Get your PCM reflashed by Jody at www.dp-tuner.com w/ the 60tow setting. If you want more options - then look at their multi position chips, SCT's or F5 chip.
2001 F350 Platinum
12.0 @ 110 FUEL ONLY
11.62 @ 115.79 SINGLE STAGE
SWAMPED
Marty is offline
post #5 of 6 (permalink) Old 01-30-2007, 01:38 AM Thread Starter
brendonv's Avatar
Thanks for the replies,
I am looking into the TYMAR.
Also, what size pipe should I run, and where should I start with the new piping?
brendonv is offline
post #6 of 6 (permalink) Old 01-30-2007, 03:15 AM
Diesel Dog's Avatar
Turbo back. 3.5 or 4 inch is plenty. If you have employees driving the truck, I'd get only a 60 tow burn on the pcm, otherwise the mpg will drop and you will buy alot of rear tires.!
Diesel Dog is offline
