My turbo likes to sing, but I'm tired of it's voice. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BigBuilder, this thread has received 14 replies and been viewed 980 times.
post #1 of 15 (permalink) Old 01-30-2007, 09:26 PM Thread Starter
Hey folks,
Probably gonna get blasted for this one, but here goes: My daily driver (99, 7.3L) has the loudest turbo whine of ANY diesel i've owned. It's mostly under low to moderate acceleration.
Is there any product or blanket or something that can quiet the turbo down? Here in ATL. i'm in traffic constantly or moderate stop light to stop light driving. Any help would be appreciated.
PS: I'm bracing myself for the "If it's too loud, you're too old" comments and the like - so fire away.
Thanks!
BigBuilder is offline
post #2 of 15 (permalink) Old 01-30-2007, 09:38 PM
Supporting Vendor
SeeYa's Avatar
Images: 1
What? You don't like the "whine of your early ninety-nine".
Seriously though. You have to change out the wheel or get a different turbo.
I'll let the guys post up as to which they preffered.
SeeYa is offline
post #3 of 15 (permalink) Old 01-30-2007, 11:27 PM
TDG MAFIA MEMBER #77
TooLoudTooBad's Avatar
Post up what mods you have done. If you have an open element intake, you can put the stock box back in and lose alot of the noise.
TooLoudTooBad is offline
post #4 of 15 (permalink) Old 01-30-2007, 11:34 PM Thread Starter
Hypertech stage 1 setting (out of a possible 3). In other words, not much. Rest of truck is bone stock.
It was this loud before i did anything. Always been this way.
Thanks!!
post #5 of 15 (permalink) Old 01-31-2007, 12:52 AM Thread Starter
Diane,
Do you mean change out the wheel inside the turbo housing (the turbine, i guess)?
And could you recommend a quieter turbo than stock?
I appreciate you taking the time to help.
post #6 of 15 (permalink) Old 01-31-2007, 01:08 AM
Diesel Dog's Avatar
Yes, the wheel on the intake side of the turbo. The one you have now is the same as the Wicked wheel so many change to to get the wine. You can change just the wheel to a 'oo and up and it will be a lot quieter.
The qssb turbo I have is a lot quieter than the old stock one with the ww in it, but if you are stock injectors you probly won't be able to light it. Some others with after market turbos will probly chime in.
Diesel Dog is offline
post #7 of 15 (permalink) Old 01-31-2007, 01:12 AM
a better stereo....seriously
post #8 of 15 (permalink) Old 01-31-2007, 01:36 AM
er
Early 99 Crew Cab Long Bed Lariat 4x4 7.3L PSD Primary Horse Hauling Rig
-Stage 1 160cc Single Shot Injectors - DP Tuner F5 - 60 Tow, 80 Econo, High Idle, Stock - NVK5 PCM thanks to DP Tuner
-Home Brew fuel system with Aeroquip socketless fittings, socketless hose, and Aeromotive Regulated Return
-4" Lift 285/75R16 E Nitto Dura Grapplers - 5" MKO Aluminized Exhaust w/6" Stainless Tip - Pair of Optima Red Tops - Napa 6637 Air Intake filter - Triple Gauge A-pillar Pod w/Autometer UltraLite:Trans, EGT, Boost - CCV Mod
ndrorydr is offline
post #9 of 15 (permalink) Old 01-31-2007, 02:13 AM
I would try wraping the CAC tubes with some foam or something before you change anyting with the turbo.
Eric
Dually Club Member #53
racehauler is offline
post #10 of 15 (permalink) Old 01-31-2007, 02:57 AM
If you decide to change the wheel out, I will give you my stock wheel (If I can find it).:shrug:
