engine block heater - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jots512, this thread has received 4 replies and been viewed 870 times.
post #1 of 5 (permalink) Old 01-31-2007, 08:34 PM Thread Starter
engine block heater
looking to install a block heater for easier cold morning start ups, can some one recommend a vendor. Can't locate one hear locally, in Austin,TX.
jots512 is offline
post #2 of 5 (permalink) Old 01-31-2007, 09:29 PM
I think the truck should have a block heater in it you just need to buy a cord for it from Ford.
Someone correct me if I am wrong.
Eric
Dually Club Member #53
racehauler is offline
post #3 of 5 (permalink) Old 01-31-2007, 09:34 PM
4cstr
What year truck do you have? I believe the earlier years they came standard. Then after Ford made it an option.
Crawl under the drivers side of the truck. Right above where the oil filter goes you will see where the block heater plugs in. If there is a cord there...trace it back to where Ford zip-tied it up...usually in the vicinity of the tow hook.
post #4 of 5 (permalink) Old 02-01-2007, 12:04 AM Thread Starter
1998 E350 van , I'll take a look later. thanks guys
jots512 is offline
post #5 of 5 (permalink) Old 02-01-2007, 12:17 AM Thread Starter
took a look, don't see a heater. I'll shop around online...
jots512 is offline
