Up pipe fell out - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by racehauler, this thread has received 13 replies and been viewed 1099 times.
post #1 of 14 (permalink) Old 02-01-2007, 06:21 AM Thread Starter
Question Up pipe fell out
I pulled the left side exhaust manifold off of my truck today because it was leaking at the head. I noticed that the up pipe would really move around a bunch and pretty soon it just fell out in my hand.
What should I do?
It doesn't look like it was leaking much at all around the top connection, just a very minor amount of soot.
I can get it back up in there but do you think it will seal? I am really needing my truck this weekend so I'm kinda looking for a quick fix.
Eric
Dually Club Member #53
racehauler is offline
post #2 of 14 (permalink) Old 02-01-2007, 06:48 AM
Ol Dirt Contractor
Lowboy's Avatar
Pipe just slipped out of the donut. If you can reach up and align the donut to get the pipe back up through, it should be good to go.
Put some duct tape on to hold the pipe up until the up pipe flange is back on the manifold...
I was Anti-Obama before it was cool!
Leno: ‘Remember the Old Days When Obama’s Biggest Embarrassment Was Joe Biden'
Ernie Hasse+ Bill Gaither America Medley
XCR 800cc Polaris Triple with Turbo, Nitrous & RMI
96 F250 7.3 Hypermax Stage III’s, H2 for now, Wide Open Performance long block. Spearco Intercooler 4” downpipe Suncoast Tranny, Terminator Oil
Newest--2015 Black VW Golf SportWagen TDI DSG Nav Roof 18" Avignon's Valentine One
Early 99 F250 SD 7.3 almost stock for now
87 Turbo Intercooled T-Bird stock
98 379 Pete 15.8L CAT 3406E 5DS Borg Warner 175963 Turbo P5 Nathan Horns Johnson Matthey 600 HP DPF 2017 CA registered emissions legal
More Milwaukee V28 Tools than Tim Allen has!
Remember, nozzle size matters at the pump
Lowboy is offline
post #3 of 14 (permalink) Old 02-01-2007, 01:19 PM Thread Starter
Is this normal?
Is it possible to get to the bolts at the top of the up pipe without pulling the transmission?
Eric
post #4 of 14 (permalink) Old 02-01-2007, 01:33 PM
fordt
It is possible, but it does take some time and manuevering. Those 'donuts' are notorious for all sorts of problems.
post #5 of 14 (permalink) Old 02-01-2007, 03:37 PM
Ol Dirt Contractor
Lowboy's Avatar
With a nice little set of 1/4” swivels and a long extension it can be done but it’s a bear! If it fell out chances are the donut in the right position will let it back up.
We called Hypermax the other day about the small Ford donuts that don’t fit good. (loose and thin) Up pipe id is 1.9” to 2.0”.. They said go to NAPA, find some and trim to fit. I had a box full of of GM donuts and cleaned some out with the die grinder to fit nice and snug. I also safety wired the top flange (donut) bolts before the motor went in. Never seize compound on the donut helps distort it to a tight fit.
After a week no soot tracks on the up pipes yet..:
Lowboy is offline
post #6 of 14 (permalink) Old 02-01-2007, 05:07 PM
if it fell out surte it will go back in but it will leak even if there is no soot its leaking and leaks there will cause a drop in boost the best fix is to replace those junk donut pipes with the bellows kit now available I have posted the part numbers by eng serial number on a few posts here already .. Navistar numbers that is
Photos of The Beast
DOC
Docluv2577 is offline
post #7 of 14 (permalink) Old 02-01-2007, 05:28 PM
Ol Dirt Contractor
Lowboy's Avatar
Doc,
Is there any chance to get a pict of the Navistar bellows kit? I might get one to play with and try to adapt to the Hypermax H2 turbo y..
Lowboy is offline
post #8 of 14 (permalink) Old 02-01-2007, 06:04 PM
Supporting Vendor
Lowboy, you don't seem to be afraid of doing the work judging from the fuel system thread. I cut the pipes and welded in the belows and then but flanges to bolt up to the hypermax exhaust Y. Something like whats on page 37. http://www.spdexhaust.com/pdfs/07_B%26W_Low_Res.pdf
Dave
D2 Hi-Performance
www.d2hiperformance.com
Proud to be a sponser of THE DIESEL GARAGE.COM!
(586) 709-2271
(586) 949-3234
Our rides
Dave P's Truck: 2002 CCSB 6.5" ProComp lift w/ 5100 Bilsteins, Crower Rods, Balanced rotating, coated rod and main bearings, ARP Head and Main studs, Fire Ringed, ported heads, machined and coated Mahle pistons, AFE stg II, Stealth pumps, BD's w/ 0.008 EH tips, D2HP Inconel exhaust valves, D2HP custom pushrods, Custom HX50 bolted to Hmax pedistal, Suncoast Comp trans, Detriot Electrac's front and rear, D2HP transfer case and 1 piece 4" Al driveshaft.
Dave D's Truck: 2002 ECLB Built Ford Tough Package 6" DR lift kit, Bilstein 5100's, 36x15.50R20 MTZ's on 20x10 114 Eagle's, Randy Ellis Bar w/4 8" Stainless ProComp 130W Lights, Custom tunes from DP Tuner, 05 Harley front end, D2HP transfer case and 1 piece Al driveshaft.
Becky P's ride: 2002 Limited Excursion, DVD, heated seats, TS and DP tunes, Edge Juice & Attitude, Dual exhaust, Bilstein stock replacments, AFE.
D2HP is offline
post #9 of 14 (permalink) Old 02-01-2007, 06:42 PM Thread Starter
Lowboy what kind of never seize are you using? Just the plain old grey stuff or some type of hi temp?
Eric
post #10 of 14 (permalink) Old 02-01-2007, 07:44 PM
Just get yourself a new donut and slather it with plain ol' antisieze. You'll most likely never have to worry about them again. But if the top of the up pipe is messed up from rubbing on the old donut then you might be needing to replace the pipe as well to get it to reseal properly.
466 on #2 only
739 with N˛O
13.544 in 1/4 mi!
Yeah I can keep up!:Thumbup:
gtspowerstroke is offline
