Engine will die. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by briandean, this thread has received 10 replies and been viewed 982 times.
post #1 of 11 (permalink) Old 02-02-2007, 09:09 PM Thread Starter
Engine will die.
I have a 2000 F350 4X4. When the outside temp is below 45 degrees, if the truck isnt warmed up it will die if you rev the engine above 2100 rpm. It will die weather your driving or just setting. It acts like a gasoline engine when it runs out of gas or you choke it too much. If you just let it set and warm up to where the guage is around at least the C it will be fine. Any ideas? The glow plugs and relay have been replaced recently.
briandean is offline
post #2 of 11 (permalink) Old 02-02-2007, 09:16 PM
My guess would be a CPS. I don't know why it would only be when cold but sometimes the darn things have a mind of their own.
OH YEAH 2:
Eric
Dually Club Member #53
racehauler is offline
post #3 of 11 (permalink) Old 02-07-2007, 01:23 AM
Are the Batteries Good Mine did that one Time and 1 of my batteries was bad.
weaselF250
weaselF250 is offline
post #4 of 11 (permalink) Old 02-07-2007, 05:29 AM
STROKIN' IT
Send a message via AIM to BigWhite250
if its really cold outside (below 30 or so) when i start mine (I also never plug mine up) it will start and the rpm's will jump up and down and when i rev the engine up and let out real quick it will die on me... it also will do this if i kinda "pep" the peddle when its in gear
2000 F-250 cc Super Duty, TS Performance 6 pos, Exhaust, AFE intake, in dash tv/dvd/mp3, Memphis 12" sub in ported box, 20x10" Mazzi Hulks with 305-55-20 Toyo Open Country A/T's, APC projector headlights, Chrome wheel-to-wheel nerf bars...uhmm plenty of other B/S! :evil:
BigWhite250 is offline
post #5 of 11 (permalink) Old 02-07-2007, 05:46 AM
TDG Mafia - Booze Runner
Snowaholic's Avatar
Have you added any aftermaket goodies to your truck. When was the last Oil change and were your batteries loaded tested lately? Has this been since your last fillup???? Just a few questions to get out of the way and 2:
2007 Dodge 3500 MegaCab Laramie CTD 4x4 Patroit Blue Just a bunch of Go fast parts and programing
Snowaholic is offline
post #6 of 11 (permalink) Old 02-07-2007, 01:39 PM
It is the cps because my 1997 f-350 7.3 was doing the same thing and i changed the cps and it has not done that to me since i changed it
BlackSmoke is offline
post #7 of 11 (permalink) Old 02-07-2007, 07:15 PM
STROKIN' IT
also it doesn't seem to do this if i start it with my chip on stock...
post #8 of 11 (permalink) Old 02-08-2007, 03:36 PM
When was the last time you changed your oil? Mine did the exact same thing and I couldn't figure it out and then I changed my oil. Fixed everything...imagine that.
73powerstroke is offline
post #9 of 11 (permalink) Old 02-10-2007, 03:35 AM Thread Starter
Not the cps. Replaced it and still does it. Will check the older batt. Had to replace one last year. Do for oil change but dont see how that would affect it. Engine doesnt know you changed oil as in computer wise. After market is exhaust and air filter but they were on it last winter and had no problem. Thanks for all the help.
post #10 of 11 (permalink) Old 02-10-2007, 04:18 AM
TDG MAFIA MEMBER #77
TooLoudTooBad's Avatar
Crazy as it sounds, some of these trucks have a hard time running right when they are short 1/2 qt of oil. My guess is that you are low on oil and when you hit the go pedal, you dont have enough oil pressure to push the injectors.
These trucks also run better on fresh oil. I run mine for 5k and can feel and hear the difference from old and new oil.
TooLoudTooBad is offline
