T/C Lockup Mod?? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by dotson90, this thread has received 3 replies and been viewed 453 times.
post #1 of 4 (permalink) Old 02-04-2007, 05:10 PM Thread Starter
Cummin' get ya some!
T/C Lockup Mod??
Has anyone done this or should i say can it be done?? i did a search and all i came up with is people doin it to there dodges
2001 Ford F-250 4X4 Extended Cab Lariat 7.3L Auto. EDGE EZ, Diablo Predator Programmer, 10k Mod, Foil Delete, ZooDad Mod, 4-in. Straight Custom Exhaust, 2 in. Blocks in front, 35 in. Pro-Comp Xtreme A/T, Rhino Lining in Bed, Limo Tint all the way around and thats about all....for now!
2000 VW Jetta TDI Manual 5 Spd. Bone Stock and averaging 45 mpg!
dotson90 is offline
post #2 of 4 (permalink) Old 02-04-2007, 05:44 PM
CSIPSD's Avatar
Here is a site that has the best write up I have seen. Daryl has good info. Go to the F-350 section.
http://www.forgotton.net/frame.html
CSIPSD is offline
post #3 of 4 (permalink) Old 02-04-2007, 06:12 PM
If you install the switch, follow his guidelines for use. Then adapt them to how and where you drive such as mountain towing etc. " You should unlock your TC at speeds below about 25mph or RPMs below 1000 so as to avoid TC damage".
Also locked below 1000 rpm could cause engine stall. Not good to lose steering and brakes in traffic.
Some chips reprogram TCC lockup and unlock rpm. You can have them programmed for your needs.
RacerX is offline
post #4 of 4 (permalink) Old 02-05-2007, 07:10 AM
love my lock-up switch, couldnt do without it
imported_DieselKid is offline
