winter millage - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by DZLpuller, this thread has received 12 replies and been viewed 802 times.
post #1 of 13 (permalink) Old 02-07-2007, 02:50 PM Thread Starter
winter millage
it seems like over the winter my truck is sucking fuel like no other i dont have a plow just chip injectors etc.. (7.3) is anybody else having this issue
DZLpuller is offline
post #2 of 13 (permalink) Old 02-07-2007, 03:06 PM
plainredtruck's Avatar
Images: 11
Always do, and I'm in SC. Drops from 21.5 to 18.5 or 19 depending on the weather and driving needs.
That's empty. Don't tow anymore except special projects around the house.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
post #3 of 13 (permalink) Old 02-07-2007, 03:48 PM
I be Architect'n
Pretty standard to have a mileage drop w/ winter blend diesel.
2K3 EXCURSION 7.3L 4x4 EDDIE BAUER 107K miles as of 06-13-07
AFE Stage II / 4" MBRP exhaust / DP-Tuner F5 (Stock, 60hp Tow, 80hp Econo, 120hp race & High Idle) / Quadzilla Commander/ATS Housing
Running homebrewed BioDiesel and custom SVO kit for 70k miles.:Thumbup:
Misc. Mods: ZooDad/By-Pass Oil Filter/203* T-Stat/Coolant Filter/HPX/CCV Reroute/Tranny Filter/Foil Delete/Stereo Stuff/ITP Reg Return/Non-EBPV Pedistal and Exhaust Housing/Adjustable Waste Gate Controller/
"If you love your motorcycle, set it free. If it comes back to you it was probably a high-side."
I'LL TRY TO KEEP UP, BUT THE EXCURSION IS A BIG GIRL AND BIG GIRLS DON'T LIKE TO MOVE FAST.
6_Myles is offline
post #4 of 13 (permalink) Old 02-07-2007, 05:11 PM
Down to 15.3
Bigburd is offline
post #5 of 13 (permalink) Old 02-07-2007, 05:40 PM
TDG MAFIA #94
StrokinSnyd's Avatar
Send a message via MSN to StrokinSnyd
ya, just about everyone dose. mine is perty poor up here in IN, about 14-16 mpg. what i have found to help is additives. i forget the name of it but it comes in a white jug with a red lid. you just add it to a tank when you fill up. it recomends every tank, but i do it once a week when it gets below 10-15 degrese. letting it set at an idel when its warming up dosent help the milage either.
96 Dodge Cummins EC LB 5 spd big valve springs, full cut DV's, Big sticks, phat shaft turbo....yada yada yada.... plain and simple, it goes fast and pulls whatever
StrokinSnyd is offline
post #6 of 13 (permalink) Old 02-07-2007, 05:50 PM
Banned
My last tank was 8.3
To much warm up time during this cold spell.
Normal in winter has been 13-15.
wastedwagesracing is offline
post #7 of 13 (permalink) Old 02-07-2007, 06:19 PM
TDG Mafia Member # 37
01blkf250's Avatar
I always lose 3-4 mpg with the winter blend fuel. That being said i still got 14.3 mpg while pulling my 24' enclosed Haulmark snowmobile trailer. This is hand figured from filling to the top of the neck to top of the neck on next fill up and dividing gallons used into miles traveled. This trailer is 4500# unloaded and I had 3 sleds and all of our gear and oil and fuel cans in the trailer, for about 7300-7500# , this was in my 60 hp tow mode. Yeeeehaaaa, Gene, :mafia
2001 F-250 XLT, cc sb 4X4, 3.73 LS,auto, Ported ATS shroud housing 1.00 exhaust housing Banks wicked wheel adjustable wastegated turbo,Non Ebpv pedestal and gutted Ebpv, DI Performance regulated fuel return kit, Dieselsites' 203* thermostat and billet housing, MBRP 4" ss turbo back exhaust system, AFE Stage 1 air intake, Jody Tiptons' F5 chip with no start,stock, 60hp tow,and 120hp race tune for now til I get big oil and injectors. Sonnax kit, Dieselsites' A/C heater core bypass valve, Autometer Boost, Pyro, and Trans temp guages in A pillar, Regulator in MAP line set at 20psi, boost tube, wastgate adjusted real tight, Aih delete, and Zoodad'ed. Amsoil fluids, Monroe Reflex shocks, and Ironman APR 265/75/16R tires.
01blkf250 is offline
post #8 of 13 (permalink) Old 02-07-2007, 09:03 PM
I looooove my winter front grill cover!!!
My best mileage ever was 18.5 in the summer and I just did a 800 mile 'round trip, all of which was below 25 degrees, and averaged 17.7 mpg. Gotta keep these things warm in the winter!:Thumbup:
FireHunter is offline
post #9 of 13 (permalink) Old 02-07-2007, 11:45 PM
Vehicles of all descriptions burn more fuel in the winter. The reason is increased aerodynamic drag. Winter air is colder and dryer than summer air, therfore it is heavier. Your truck still has to bulldoze the same CFM out of the way but it weighs more therefore has greater resistance to being moved.
All efficiency research shows a dip in the efficiency during the winter months.
Dave Whitmer is offline
post #10 of 13 (permalink) Old 02-08-2007, 05:57 PM
TDG MAFIA #94
well, there you go. you got the scientific explenation and the regular joes explenation, everybody should be all happy happy now!!
