New Mods - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cchildress, this thread has received 2 replies and been viewed 459 times.
post #1 of 3 (permalink) Old 02-07-2007, 05:00 PM Thread Starter
New Mods
I have been reading on Steve Baz site and found out how to do the 10k mod, and EOT mod. I was wondering if they are worth doing and if I may have any problems doing them. Everything that i have done to my truck is in my sig. Thanks alot!!!!!!!
cchildress is offline
post #2 of 3 (permalink) Old 02-07-2007, 06:42 PM
You dont need a 10k mod. Your chip does everything that would.
I am not really sure what the EOT Mod is.
Eric
Dually Club Member #53
racehauler is offline
post #3 of 3 (permalink) Old 02-08-2007, 04:23 AM Thread Starter
Thanks! The PCM uses the EOT to help determine the injection timing. Cold oil has more advanced timing. Warm oil has less advanced timing. The EOT sensor is connected with two wires. Either wire can be cut and spliced with a resistor. The values that have been tried are: (0.5k 1k 1.5k and 4.1k). The 4.1k ohm has the most effect on advancing injection timing. When this resistor is wired in series with the EOT, the PCM is fooled into thinking that the engine oil temperature is lower than actual. Lower engine oil temperature causes an advance in timing. This is out of steve bazs site. Other than this and the 10k mod what should I do next to my truck?
