Water Pump??? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by StrokerDude, this thread has received 10 replies and been viewed 1200 times.
post #1 of 11 (permalink) Old 02-07-2007, 07:23 PM Thread Starter
StrokerDude's Avatar
Water Pump???
I think my water pump might be giving me problems, but I am not sure if that's what it is. Hoped that if I described what I see, someone could tell me.
  • I have a coolant leak, only a drip when I park.
  • Not consistent (as in it does not do it every time the truck is parked).
  • I am pretty sure it is not a hose.
  • If I look up and feel from underneath the truck, the water is dripping off the lip of the oil pan where the front main seal is.
  • There is no coolant in the oil.
  • It seems that there is moisture directly above where it is dripping too, like it is coming from that cover that is on the front of the motor.
  • The motor has been over-revved a couple time (from using first in parking lots and occaisonally forgetting to pop it up into drive when hitting the road)
:shrug: :shrug: :shrug:
I personally think that it has something to do with the water pump, dont no if that means the seal around it is bad or if over-revving messed it up. :shrug:
At any rate, anyone who thinks that is my problem too or has a better idea, help would be appreciated. Also, any idea what a new pump would cost??
Thanks guys. Y'alls info on this site has been very helpful.
Alex C.
StrokerDude is offline
post #2 of 11 (permalink) Old 02-07-2007, 08:19 PM
plainredtruck's Avatar
Images: 11
Sounds like the water pump to me. Mine did what you describe intermittently for nearly a year before it started yelling at me one morning pulling into the office parking lot.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
post #3 of 11 (permalink) Old 02-07-2007, 08:20 PM Thread Starter
how much did it cost ya to replace??? parts that is, I do my work myself.
Alex C.
post #4 of 11 (permalink) Old 02-07-2007, 09:30 PM
Images: 11
About $180 at NAPA + thermostat o-ring and/or RTV.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
Mafia # 27
post #5 of 11 (permalink) Old 02-08-2007, 08:44 PM Thread Starter
It started making noise at me this morning. Sounds similar to a bearing goin. Guess I'm gonna have to replace it. Gota price of 200 at autozone with lifetime warranty. Glad I have a buddy there that gets me a discount.
I figured I have might as well replace all the coolant instead of trying to save what is in the radiator now, anybody know how much coolant it holds?? Early 99 7.3 thanks yall.
Alex C.
post #6 of 11 (permalink) Old 02-08-2007, 11:40 PM
Images: 11
A whole heapin' bunch of coolant.
32 quarts, but I got about 30 - 31 in mine.
Do you have a coolant filter? If not, think hard about getting one about now. It's easy enough to install and I got the one from www.dieselsite.com as well as the 203* thermostat and billet housing. You'll have to get a new housing, probably anyways, so get a nice one from them.
Get yourself about 20 gallons of distilled water and flush the system really well. Drain, re-fill with distilled water; repeat 2-3x or until you only have 4 gallons of distilled water left. Don't forget to have your heater valve open - run it full tilt during the flush process.
I used concentrated coolant, not pre-mixed. That way I only needed 4 gallons. Get yourself a couple of big drain pans and some 5 gallon buckets with lids in which to place your old coolant and drain water.
I broke the "rules" and went with Fleetrite ELC from the local International dealer. I did this before the water pump actually gave up the ghost - about 7 months or so. I don't think it affected the lifespan since the wp was already on it's last leg.
Or you could check out Evans coolant - water and pressure free. Also at www.dieselsite.com IIRC
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
Mafia # 27
post #7 of 11 (permalink) Old 02-10-2007, 02:11 AM Thread Starter
Thanks PRT, if finances would have allowed me to do so I would do all the things you mentioned. Finances though said I could only buy the new pump, flush the system and put in new coolant, but I got er dun anyway.
Alex C.
post #8 of 11 (permalink) Old 02-11-2007, 12:19 AM
idunnoyet
barbershop's Avatar
My Uncle was experiencing similair symptoms on his 99. While going down the road the water pump didn't just give up the puuly let go and went into the fan which in turn went throught the radiator, you get the picture. It cost him just over $1000.00 and that was doing it himself..... therefore i do not recommend driving with any noise from the water pump.
2012 Z-71 Duramax
1987 379 Peterbilt 425 Cat, RTX 15715, 390 rear ends.
1994 379 Peterbilt 425 Cat, 9 speed, 3:70 rears
Also drive anything that is overloaded and fast!!
CAN YOU KEEP UP!?!?!?!?
barbershop is offline
post #9 of 11 (permalink) Old 02-11-2007, 03:36 AM
In case you want to know what it costs to have a shop do it - I paid $606 to have my water pump replaced last year. I was tight on time and couldn't do it myself. I guess you have to get used to paying through the nose when your sending the mechanics kids thorugh college
KEG99 is offline
post #10 of 11 (permalink) Old 02-11-2007, 04:37 AM
when my waterpump on my 95 went it was like a geyser coming out of that thing, much more then a little drip
DBogo is offline
