Help - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by stroke73, this thread has received 4 replies and been viewed 452 times.
post #1 of 5 (permalink) Old 02-09-2007, 12:13 AM Thread Starter
Angry Help
on my 01 7.3 when im going down the road and let off the accelerator a little bit, it makes a weird grinding sound . it only makes the noise then , i have not noticed it at any other time. if anyone knows about it please help.Thanks for looking.
stroke73 is offline
post #2 of 5 (permalink) Old 02-09-2007, 12:43 AM
CSIPSD's Avatar
U joints? Or front hubs... Are your hubs locked?
CSIPSD is offline
post #3 of 5 (permalink) Old 02-09-2007, 01:05 AM
pontiacross's Avatar
can you tell if its comming frome the front or back of the truck? it could be a bearing going out of the rearend or transmission you might check the oils and see if you can find any metal.
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #4 of 5 (permalink) Old 02-09-2007, 02:23 AM
Diesel Dog's Avatar
It also may be a cracked flywheel or loose torque converter.
Diesel Dog is offline
post #5 of 5 (permalink) Old 02-09-2007, 03:45 AM
A friend of mine was doing the same thing. his is a 4wd. i check it out and find out the bearings in the front hubs were bad on the left side. if yours is 4wd u can grab a hold of the axle shaft between the axle tube and the hub. if u can move it that aint good.
Roscoe Stroker is offline
