Check Engine Light - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Smoky, this thread has received 5 replies and been viewed 472 times.
post #1 of 6 (permalink) Old 02-09-2007, 07:05 PM Thread Starter
Check Engine Light
This all started the other morning when I started my truck and for whatever reason the check engine light came on. It was about 8 or so degrees outside. The truck runs fine no problems. So I went to "chevy zone" (aka auto zone) due to the fact that they are the only ones who are still doing the comp scans. Well turns out the scanner wouldn't come on. The guy said the comp is probably going bad or something. Im no idiot. If the comp was bad the truck wouldn't run. If anybody had a clue what is going on please help. :shrug: Thanks 00 CC SB 7.3 AFE Stg 2 Ts chip MBRP 5" autometer guages
Smoky is offline
post #2 of 6 (permalink) Old 02-09-2007, 07:12 PM
Supporting Vendor
Check the fuse under the dash for the OBDII. The scanner should get power from the OBDII port if it isn't something is wrong. Will need to know what the code is before we can really help you. You could disconnect the batteries for a little while to clear the codes and see if it comes back.
D2 Hi-Performance
www.d2hiperformance.com
Proud to be a sponser of THE DIESEL GARAGE.COM!
(586) 709-2271
(586) 949-3234
Our rides
Dave P's Truck: 2002 CCSB 6.5" ProComp lift w/ 5100 Bilsteins, Crower Rods, Balanced rotating, coated rod and main bearings, ARP Head and Main studs, Fire Ringed, ported heads, machined and coated Mahle pistons, AFE stg II, Stealth pumps, BD's w/ 0.008 EH tips, D2HP Inconel exhaust valves, D2HP custom pushrods, Custom HX50 bolted to Hmax pedistal, Suncoast Comp trans, Detriot Electrac's front and rear, D2HP transfer case and 1 piece 4" Al driveshaft.
Dave D's Truck: 2002 ECLB Built Ford Tough Package 6" DR lift kit, Bilstein 5100's, 36x15.50R20 MTZ's on 20x10 114 Eagle's, Randy Ellis Bar w/4 8" Stainless ProComp 130W Lights, Custom tunes from DP Tuner, 05 Harley front end, D2HP transfer case and 1 piece Al driveshaft.
Becky P's ride: 2002 Limited Excursion, DVD, heated seats, TS and DP tunes, Edge Juice & Attitude, Dual exhaust, Bilstein stock replacments, AFE.
D2HP is offline
post #3 of 6 (permalink) Old 02-09-2007, 07:12 PM
KT Performance's Avatar
I would just spend the money and go to a shop to pull it up. Most like likely the scanner at Auto Zone won't find what you need. Did the light go away once the motor warmed up?
KT Performance is offline
post #4 of 6 (permalink) Old 02-09-2007, 07:18 PM Thread Starter
The light is still on. I will check the fuse under the dash. Hopefully that is part of the problem. I guess I could disconnect the batteries but I would like to find out what code it is throwing. I'll get back to ya on the fuse
Smoky is offline
post #5 of 6 (permalink) Old 02-09-2007, 07:52 PM Thread Starter
The fuse was blown. Went back to chevy zone and now I have to retract a previous statement, I am an idiot. The damn cap on the fuel tank apparantly wast tight enough. Funny thing is though, it had been that way for about two weeks. I live 10 min from work so i dont use alot of fuel. It also still had a 1/4 tank of fuel left. Go ahead and laugh it uplaugh Thank God it wasn't something worse. Thanks for everone's help
Smoky is offline
post #6 of 6 (permalink) Old 02-09-2007, 07:58 PM
Supporting Vendor
10-4 glad it was an easy one!
Dave
D2 Hi-Performance
(586) 709-2271
(586) 949-3234
Our rides
D2HP is offline
