Tires - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Slacker, this thread has received 10 replies and been viewed 708 times.
post #1 of 11 (permalink) Old 02-10-2007, 03:53 AM Thread Starter
David
Tires
Can load range D tires be run on a 96 OBS PSD?
If more is better, then way too much is just about right
96 F250 PSD 4x4 cc srw 3" dp Jardine 4" exhaust homemade intake bb'd fpr superchip
Slacker is offline
post #2 of 11 (permalink) Old 02-10-2007, 06:38 AM
circle5's Avatar
Why not just run E's
circle5 is offline
post #3 of 11 (permalink) Old 02-10-2007, 07:45 AM
moose99psd's Avatar
you can run almost any load range.. what do you haul with the truck? some load ranges vary some companys D's will actually hold more than other companies E's
moose99psd is offline
post #4 of 11 (permalink) Old 02-10-2007, 08:02 AM
Tires
I put some serious weight on some C's. But that's just me.....look at the truck!
Fast_Ashley is offline
post #5 of 11 (permalink) Old 02-10-2007, 01:37 PM Thread Starter
David
I can get a hold of some Cooper Discover S/T 285-75r16 load range d tires dirt cheap from a guy. I have e range on the truck now. I drag a lowboy trailer with 4 wheelers most of the time. Sometimes a lowboy full of firewood.
Slacker is offline
post #6 of 11 (permalink) Old 02-10-2007, 03:48 PM
KT Performance's Avatar
You should not have any problem with "D's" if thats all the weight your going to pull.
KT Performance is offline
post #7 of 11 (permalink) Old 02-10-2007, 08:02 PM
Check the "max load single" rating on the tires. Take that times 2 (because you have 1 on each side) and that would be the maximum amount of weight you can have on each axle.
More than likely those tires will be pleanty heavy duty enough. The weight rating on those tires will probably be very similar to a 245/75/16 E tire. Larger tires are always rated for more weight capability than smaller tires in the same load range.
Eric
Dually Club Member #53
racehauler is offline
post #8 of 11 (permalink) Old 02-10-2007, 08:08 PM
Got Diesel?
Send a message via AIM to WNYPA
Its not just what you haul, but also what you do with the truck, there is more than just weight rating to an "E" class tire, I personally won't run C's anymore I plow snow and want the 10ply tire.
I ran "C"'s last year and they got chopped up pretty bad. a bit of sidewall roll, and squat in the tire can do alot to the treadwear. I think the price difference on tirerack was like 10$ a tire for the E's
2000 F-350 NVK5, XLT Island Blue 7.3 PSD 3:73LS Reg Cab LB, 151,000 mi. and counting! STOCK EXCEPT:BTS Transmission, 6.0 Trans Cooler, AutoEnginuity 3.4, GI-normous, Home made Tymar, CCV mod, HX-MOD, Heater-plug mod, "Custom 6-pos Chip", Autometer Z-Series Gauge pod, Beans Stage 2 Single-Shots, Zerex G-05 Coolant, Kenwood Excelon KDC-X869/Sirius Satilite, 8" Fisher plow, 407.1 hp / 849.1 ftlbs 13.686 @96.69
In Proud Support of Fat Kid Pullers! Keep on Pullin Joe and Brian!!! :bow:
WNYPA is offline
post #9 of 11 (permalink) Old 02-10-2007, 09:11 PM
The tires you'll see in my sig are low range D. This is the highest load range I could find for my 16.5 wheels in an A/T tire. Once I wear these out I'll get different wheels and get atleast load range E. Now if I go with 19.5 wheels, which I'm hoping for, then I'll have F or G range tires:Thumbup: Anyone here running 19.5 wheels on their SRW?
Tim
Early 99 Crew Cab Long Bed Lariat 4x4 7.3L PSD Primary Horse Hauling Rig
-Stage 1 160cc Single Shot Injectors - DP Tuner F5 - 60 Tow, 80 Econo, High Idle, Stock - NVK5 PCM thanks to DP Tuner
-Home Brew fuel system with Aeroquip socketless fittings, socketless hose, and Aeromotive Regulated Return
-4" Lift 285/75R16 E Nitto Dura Grapplers - 5" MKO Aluminized Exhaust w/6" Stainless Tip - Pair of Optima Red Tops - Napa 6637 Air Intake filter - Triple Gauge A-pillar Pod w/Autometer UltraLite:Trans, EGT, Boost - CCV Mod
ndrorydr is offline
post #10 of 11 (permalink) Old 02-10-2007, 10:19 PM
Tires
I put some serious miles (like 60,000) on my last set of 42" swampers (C's)
You just have to rotate them religiously.
