what size exhaust to get? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jackedupF350, this thread has received 6 replies and been viewed 816 times.
post #1 of 7 (permalink) Old 02-10-2007, 06:29 PM Thread Starter
I got a y2k psd 6spd and I am going to put a straight pipe on it. My dad's old psd had a 4" downpipe, 4" straight pipe and 5" tip and it sounded good. His new truck (dodge :shrug: ) has a 5" straight pipe on it. Has anyone put a 5" straight pipe on a psd? Also, would there be a power loss with a more open exhaust? A guy I know said that he was thinking about going with a 3" downpipe, 4" straight pipe to the back of the cab, then 5" rest with a 6" tip. What would be the best route to go....4" or 5"?
jackedupF350 is offline
post #2 of 7 (permalink) Old 02-10-2007, 06:31 PM
moose99psd's Avatar
4" is plenty big enough.. 4" turbo back loose the muffler or go with a aeromotive... you will be happy
moose99psd is offline
post #3 of 7 (permalink) Old 02-10-2007, 06:49 PM Thread Starter
ok, well I'm going to have a local exhaust shop put it on and he loves diesels and is trying to talk me into having the exhaust come out in front of the rear tire, wouldn't that just get soot all over my wheel?
post #4 of 7 (permalink) Old 02-10-2007, 06:57 PM
moose99psd's Avatar
yes it gets soot all over the wheel... almost impossible to keep the tire and wheel clean... and the rest of the truck behind the tire... to each his own but i dont like it...
post #5 of 7 (permalink) Old 02-10-2007, 08:06 PM
There is also a bunch more in cab noise when you exit in front of the rear tire.
Eric
Dually Club Member #53
racehauler is offline
post #6 of 7 (permalink) Old 02-11-2007, 02:44 AM
soot junkie
I ran 5" on mine before the stacks. I loved the sound. It's a much deeper tone than 4". I didn't notice a power loss either. Our motors are not as sensitive to back pressure as some of the newer engines are.
01 F350 CC Dually, DP tuner, fuel system w/Aeromotive pump, 360cc Stage III Hybrids, Stealth Big Oil, H2 Hybrid, Head Studs, Hypermax rods, balanced rotating assembly, Comp Cams valve springs and push rods, ATS trans fixed by BTS, Best 1/4 [email protected] best 1/8 [email protected]
2000 F250 6sp, Dp Tuner
Early 99 F350 2wd daily driver Dp Tuner
smokin dually is offline
post #7 of 7 (permalink) Old 02-11-2007, 04:50 AM Thread Starter
is there anywhere i can hear a sound clip or see a video of a psd with 5" exhaust?
