gauge question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 99stroke, this thread has received 2 replies and been viewed 441 times.
post #1 of 3 (permalink) Old 02-11-2007, 05:28 PM Thread Starter
member
gauge question
just bought gauges and was wondering how do you splice in to the map with a (T) crazy question where is the map sensor at? does it look like a mustangs map sensor? Also where can a man find the tubing:shrug: , lowes or homedepot or advance? Thanks
99stroke is offline
post #2 of 3 (permalink) Old 02-11-2007, 06:10 PM
circle5's Avatar
boost line comes off the passenger manifold up to a round thing mounted on the firewall.
The tubing should have came with the gauge
circle5 is offline
post #3 of 3 (permalink) Old 02-12-2007, 02:43 PM
CSIPSD's Avatar
The map sensor is on the pass side up by the fire wall. Your gauge supplier should have send some 1/8 tubing, but if not a auto supply place should have it. You will need some kind of T. I use a Brass T fitting with two 1/4" barbed fittings and a 1/8" compression fitting. Install somewhere on the line shown in the pic...
CSIPSD is offline
