code reader for 95 psd - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by neeps jeeps, this thread has received 4 replies and been viewed 837 times.
post #1 of 5 (permalink) Old 02-12-2007, 04:52 PM Thread Starter
I just bought a 95 psd f-350 and I need to check for codes, I read somewhere that many of these have been reflashed and can use a obd2 code reader, if not what can i use?
I am considering having my chip reflashed with a performance file, should i get this done so i can use a later code reader?
i want to be able to do diagnostics and i have several other cables and programs for other vehicles, i just want to buy the better one now and not have to replace it when i do upgrades to the computers
neeps jeeps is offline
post #2 of 5 (permalink) Old 02-13-2007, 02:00 AM
So why you feel teh need to check the codes? Is the truck having problems? Instead of reflashing the computer w/ a performance file, have you thought about getting a chip w/ multiple settings?
As far as a code reader, I've never seen a "good" one that will read other vehicles as well.
imported_BigGreen is offline
post #3 of 5 (permalink) Old 02-13-2007, 02:10 AM Thread Starter
yes i have thought about that but i also have to reflash the 95 ecu to be able to use obd2 port (according to Jody at DP Tuners) and then i can add a chip or have him program the ecu for performance or add a chip.
the problem with my truck is in the other post i have and it has gotten worse today. the oil pressure gauge started going nuts, and it always runs rough, used to be intermittent:shrug:
post #4 of 5 (permalink) Old 02-17-2007, 11:56 PM
I have been told that all Powerstokes are OBD2
ScottyB is offline
post #5 of 5 (permalink) Old 02-18-2007, 05:18 PM
Not quite true. OBD2 compliant was for passenger cars by 1996. We have the obd2 port if it's under the dash. Some 94.5'/95 have under hood ports. Our PCM's can't be read by common OBD2 scanners like the free scan Autozone offers. The early PCM's are just a breed of their own.
Auto Enginuity readers will scan them. Super chips tuners with self tests also can scan them.
RacerX is offline
