Egt? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by HawaiianPSD, this thread has received 3 replies and been viewed 489 times.
post #1 of 4 (permalink) Old 02-13-2007, 06:24 AM Thread Starter
Egt?
How much of a temp. difference would there be if the probe was mounted 6"- 8" after the driver side manifold?
Reason I ask, didn't wanna drill my manifold on the truck so I placed the probe into the pipe that connects to the manifold itself (dunno the actual name of that pipe though). Thanks guyz!
01' F-250 CC 4X4 6spd
5" straight pipe w/ 6"SS Tip, AFE Stage II, DP 20/40/60HP tow/80Econo/120race/140agressive, Southbend Clutch, 6" all spring SuperLift w/ Bilsteins, 35X14.5 Swamper SSR's on ProComp 1059's, boost/pyro guages
HawaiianPSD is offline
post #2 of 4 (permalink) Old 02-13-2007, 06:39 AM
TDG MAFIA MEMBER #71
POWER STROKE 99's Avatar
Not much if any from what I have read, CSIPSD has two on his truck, I think that is what I read, and he said their is not any difference. Mine is in the up-pipe right near the bend and I get a good reading, it is about 4" from the manifold collector.
POWER STROKE 99 is offline
post #3 of 4 (permalink) Old 02-13-2007, 08:49 AM Thread Starter
Right on! Mine is a few inches upstream from yours.
post #4 of 4 (permalink) Old 02-13-2007, 03:37 PM
CSIPSD's Avatar
The farther up the pipe the lower the EGT's will be... How much differant I dont know but If your that much above the one shown I would use 1200-1250 as your red line. My up pipe pyro is about 1" from the manifold...
CSIPSD is offline
