fuel filter - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by seventhree, this thread has received 13 replies and been viewed 1069 times.
post #1 of 14 (permalink) Old 02-14-2007, 12:55 AM Thread Starter
fuel filter
whats the life of a fuel filter???? and anyone kow how much they are. are there aftermarket fuel filters that are better then others?????? thanks for the help guys
seventhree is offline
post #2 of 14 (permalink) Old 02-14-2007, 01:04 AM
member
I change mine at oil changes...Slept since I bought one but I think mine was like $25-30. Brand wise, I just stuck a ford one in I am sure there are better ones.. Wix is a good one also. I usaully drain mine every other fill up just to be on the safe side.
99stroke is offline
post #3 of 14 (permalink) Old 02-14-2007, 01:19 AM
pontiacross's Avatar
I usually change mine every oil change too, but you probably dont need to. I run fleetguard filters I think they run about $15 but can very quite a bit depending where you buy them.
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #4 of 14 (permalink) Old 02-14-2007, 03:51 AM
TDG MAFIA MEMBER #77
TooLoudTooBad's Avatar
Normally I change mine out every 10k. SPDiesel (A supporting vendor here) sells 3 shipped to your door for around $40 and some change. Not sure what brand they are, but I compared one of them to my 35 dolar NAPA filter and it looked the same.
TooLoudTooBad is offline
post #5 of 14 (permalink) Old 02-14-2007, 10:56 AM
I'm ripping that little bowl thing out of my truck this weekend. Going with a pre-pump setup with a fuel/water sep. and secondary spin-on fuel filters. I'll post pics when I'm done. Only reason I'm going pre-pump is that's the most convenient location for install.
Tim
Early 99 Crew Cab Long Bed Lariat 4x4 7.3L PSD Primary Horse Hauling Rig
-Stage 1 160cc Single Shot Injectors - DP Tuner F5 - 60 Tow, 80 Econo, High Idle, Stock - NVK5 PCM thanks to DP Tuner
-Home Brew fuel system with Aeroquip socketless fittings, socketless hose, and Aeromotive Regulated Return
-4" Lift 285/75R16 E Nitto Dura Grapplers - 5" MKO Aluminized Exhaust w/6" Stainless Tip - Pair of Optima Red Tops - Napa 6637 Air Intake filter - Triple Gauge A-pillar Pod w/Autometer UltraLite:Trans, EGT, Boost - CCV Mod
ndrorydr is offline
post #6 of 14 (permalink) Old 02-14-2007, 09:10 PM Thread Starter
where is the fuel filter located and do i need to do anything special to change it???
post #7 of 14 (permalink) Old 02-14-2007, 09:30 PM
Also the life of the fuel filter is directly affected by the quality of fuel you buy.
2001 Dodge quadcab 4x4,Auto transmission,Fass 150/150 pump, Among other upgrades.
todt061458 is offline
post #8 of 14 (permalink) Old 02-14-2007, 09:46 PM
plainredtruck's Avatar
Images: 11
On the '99-03's the factory recommends 15K change intervals with 5K drains.
I'm with ndrorydr on this one. Mine's going away.
todt061458 is also correct here. Quality of fuel makes a huge difference.
So does the quality of the filter. That's why I'm going to put Dahl 100's on mine.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
post #9 of 14 (permalink) Old 02-14-2007, 10:32 PM Thread Starter
anyone know where the fuel filter is??? im tryin to change it right now among other things.....thx
post #10 of 14 (permalink) Old 02-14-2007, 10:40 PM
What year truck do you have? Their all underneath the powerstroke cover on the top of the motor. Its a black plastic cap about 4.5" around.
Fast_Ashley is offline
