Fuel pressure at the pump - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Fast_Ashley, this thread has received 3 replies and been viewed 424 times.
post #1 of 4 (permalink) Old 02-15-2007, 04:41 AM Thread Starter
Does anyone know what the factory fuel press. at the pump is? What is too much pressure, and what is optimal fuel press. from the tank to the filter bowl? Thanks.
Fast_Ashley is offline
post #2 of 4 (permalink) Old 02-15-2007, 04:59 AM
TDG MAFIA MEMBER #71
POWER STROKE 99's Avatar
Not sure on factory pressure or what is to much, My fuel pressure runs @ 62psi almost all the time and the transmitter is in the back of the bowl. Not sure if that help but thought I would put it out their for ya.
POWER STROKE 99 is offline
post #3 of 4 (permalink) Old 02-15-2007, 05:29 AM
TDG Mafia Member # 37
01blkf250's Avatar
IIRC International says fuel pressure should be between 62-68 psi. Ford from what I have read from post on shimming the regulator seems to set it around 53-55, mine was at 53. I can tell you that when I shimmed mine it was more responsive and quieted down some of the injector noise. I shimmed mine up to 70 psi, but now I have regulated return kit and have it set at 68 psi. Hope this helps ya, Gene :mafia
2001 F-250 XLT, cc sb 4X4, 3.73 LS,auto, Ported ATS shroud housing 1.00 exhaust housing Banks wicked wheel adjustable wastegated turbo,Non Ebpv pedestal and gutted Ebpv, DI Performance regulated fuel return kit, Dieselsites' 203* thermostat and billet housing, MBRP 4" ss turbo back exhaust system, AFE Stage 1 air intake, Jody Tiptons' F5 chip with no start,stock, 60hp tow,and 120hp race tune for now til I get big oil and injectors. Sonnax kit, Dieselsites' A/C heater core bypass valve, Autometer Boost, Pyro, and Trans temp guages in A pillar, Regulator in MAP line set at 20psi, boost tube, wastgate adjusted real tight, Aih delete, and Zoodad'ed. Amsoil fluids, Monroe Reflex shocks, and Ironman APR 265/75/16R tires.
01blkf250 is offline
post #4 of 4 (permalink) Old 02-15-2007, 05:23 PM
we shoot for around 65-75 psi here anything in that range will make her run better if its lower than that now.
Photos of The Beast
DOC
Docluv2577 is offline
