Block heater problem - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by DIESEL73, this thread has received 9 replies and been viewed 1028 times.
post #1 of 10 (permalink) Old 02-17-2007, 08:39 PM Thread Starter
Michigan Redneck
DIESEL73's Avatar
Every time I plug it in, it trips the circuit on my GFI wall plug.
Is there a common problem with these things? I've tried different extension cords too.
Any help is appreciated.
2003 F-350 CREW CAB LARIAT FX4 7.3L
BDS LEVELING KIT-35" MT'S BAJA CLAW'S-RHINO LINER-K&N FIPK-SUPERCHIPS PROGRAMMER-SONNAX SHIFT KIT-4" SS EXHAUST-BIGG BOOST MODULE-COBRA 29LTD C.B.-SIRIUS SATELITE RADIO-COBALT GAUGES-STEVERACER MOD-DO DAD MOD
DIESEL73 is offline
post #2 of 10 (permalink) Old 02-17-2007, 08:45 PM
4cstr
Check the plug on the truck. The plug that goes into the extension cord. These things just get beat hanging out there in the wind, and there might be short there. I had mine short on that plug...and it melted to the extension cord.
You can see here how I re-wired mine:
license plate mod
post #3 of 10 (permalink) Old 02-17-2007, 08:45 PM
TDG MAFIA MEMBER #71
POWER STROKE 99's Avatar
It has a short in it, pull the plug off of the block and inspect it. Also double check the wiring going to the front of the truck. other than that the block heater it's self may have a short.
POWER STROKE 99 is offline
post #4 of 10 (permalink) Old 02-18-2007, 03:20 AM
make sure you dont have any water or snow in the pulg or the cord i have this problem once in a while i have to bring the cord into the house and let it dry out cause it gets ice in it and causes it to trip the GFI plug just a thought
scott
scott47429 is offline
post #5 of 10 (permalink) Old 02-18-2007, 06:00 PM Thread Starter
Michigan Redneck
DIESEL73's Avatar
Thanx for the response.
I'm going to replace the end of the plug, hopefully that will do the trick.
DIESEL73 is offline
post #6 of 10 (permalink) Old 04-06-2007, 01:41 AM
CBCS
that's what happens to mine. its a pain, but a warm truck is nice
bigbear3 is offline
post #7 of 10 (permalink) Old 04-06-2007, 05:01 PM
I had this problem and it ended up being a little road salt on the plug. Bought some electric contact cleaner from the autoparts store, sprayed the plug, let it dry and plugged it in and it didn't trip the GFI anymore. Just some food for thought before you cut the end of to replace the plug.
-Mike
Early '99 (Built 06/98) F-350 XLT SRW 4x4 Reg. Cab 7.3L 6-speed, AFE Stage II w/ Progaurd 7 Filter, (Pre-Turbo) Pyro and Boost Gauges, MBRP 4" turbo back straight piped, South Bend Con OFE clutch, '01 Headlights, Hella Micro FF Fog and Driving Lights, '06 Travel Tow Mirrors, DP Tuner F5 (Stock, 60T, 80E, 120)
mwierowski is offline
post #8 of 10 (permalink) Old 04-06-2007, 10:58 PM
biz
Keep a close eye on it.
when I bought my truck 4 months ago... i decided to plug it in, this was on the second night of owning the truck.
my wife woke me up screaming at 1:30 am. there was flames rolling up around my bumper.
the wire had a short and somehow heated up the bumper and melted the plate holder and the entire plastic skirt off the bumper.
I had a 2 foot diameter puddle of plastic in my driveway.
luckily it didnt melt the grille at all.
I ran out there just in time with a fire extinguisher.
the dealer fixed it.
2000 F-350 Super cab, Tadds tunes, AFE Pro Guard intake, 4" MBRP cool Duals, Nexus Gauges , Tubonetics Ball Bearing Turbo.
biz is offline
post #9 of 10 (permalink) Old 04-06-2007, 11:24 PM
Glad to here it wasn't any worse than that...............
post #10 of 10 (permalink) Old 04-07-2007, 03:10 AM
Biz, did u go and buy a lottery ticket after that??!!!
Fast_Ashley is offline
