white smoke on cold start ? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by youngPSD, this thread has received 29 replies and been viewed 3275 times.
post #1 of 30 (permalink) Old 02-19-2007, 01:33 AM Thread Starter
when i start my truck after a day at work its had white smoke coming out the exhaust its been 10-20 deg outside. I just want to know what is going on here?? my truck only has 65,000 miles. and it doesnt do it if i had it pluged in at my house. :shrug:
2002 f-250 supercab shortbed on 305/70/16 BFG A/T with 3.73 gear MODS Pyro,Boost,TransTemp Guages 4" MBRP Turbo back exhaust
youngPSD is offline
post #2 of 30 (permalink) Old 02-19-2007, 01:50 AM
sounds like the oil is to thick i have been told rotella 15w40 isnt good oil for cold starts with out it being pluged in
scott
scott47429 is offline
post #3 of 30 (permalink) Old 02-19-2007, 01:53 AM Thread Starter
well i run motorcraft 15w40 but its the same weight. so is it bad on the engine or what?
youngPSD is offline
post #4 of 30 (permalink) Old 02-19-2007, 02:06 AM
the weight is ok but its the name brand i was told not to use i use Amsoil 15W40 or the 10W40 diesel
scott
post #5 of 30 (permalink) Old 02-19-2007, 02:23 AM Thread Starter
then what is making it smoke when its cold? Are you telling me the brand of oil makes it smoke ???
youngPSD is offline
post #6 of 30 (permalink) Old 02-19-2007, 02:34 AM
no its not totaly the brand these 7.3s use oil pressure to fire the injectors and the cold oil is what makes them do it thats why i use a synthetic oil it dojnt get thick when cold like reguler oils do
scott
post #7 of 30 (permalink) Old 02-19-2007, 02:41 AM Thread Starter
That makes more sense that the synthetic oil will help out Just that one key word makes a world of difference Thanks for helping me out!!
:thanks:
youngPSD is offline
post #8 of 30 (permalink) Old 02-19-2007, 02:44 AM
no problem
scott
post #9 of 30 (permalink) Old 02-19-2007, 11:17 PM
Not sure if I agree with that.
Too thick of oil can cause it not to run (if it can't build enough pressure to fire the injectors). But I don't think it has anything to do with white smoke.
White smoke is unburnt fuel. When you first start your engine on a cold morning it will not be able to burn completely, causing the white smoke. when it warms up a bit it goes away. Most diesels do this, its not a problem.
ScottyB is offline
post #10 of 30 (permalink) Old 02-19-2007, 11:21 PM
The oil has NOTHING to do with it.
You need to ohm your glow plugs out and make sure the glow plug relay is working.
gregrob is offline
