Black Soot - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by coreystroke02, this thread has received 3 replies and been viewed 646 times.
post #1 of 4 (permalink) Old 02-19-2007, 01:33 PM Thread Starter
coreystroke02
coreystroke02's Avatar
Black Soot
I was under my hood yesterday and noticed black soot on the firewall behind the engine. It appears to be on both sides of the motor. Any idea of what might be causing this? I checked my downpipe for any leaks, but didn't see anything wrong. Could I have a manifold leak? Please help; trying to get ready for Smokin' in April.
2002 F-250 Crew Cab 4x4, DP-Tuner 60 tow, 80 eco, 120 race, and 140 smoke, Banks wastegate, Banks Transcommand(bypassed), 4" SS exhaust, AFE stage 2 intake, Superlift 6" lift, 37" Nitto Terra Grapplers, 18" Motto wheels, EGT and Boost gauges.
coreystroke02 is offline
post #2 of 4 (permalink) Old 02-19-2007, 01:37 PM
Supporting Vendor
The up pipes that feed the turbo, this is a pretty common leak. They have the old school donuts to try and seal them up. If you were planning on some trans upgrades it would also be a good time to do the up pipes because of the access.
D2 Hi-Performance
www.d2hiperformance.com
Proud to be a sponser of THE DIESEL GARAGE.COM!
(586) 709-2271
(586) 949-3234
Our rides
Dave P's Truck: 2002 CCSB 6.5" ProComp lift w/ 5100 Bilsteins, Crower Rods, Balanced rotating, coated rod and main bearings, ARP Head and Main studs, Fire Ringed, ported heads, machined and coated Mahle pistons, AFE stg II, Stealth pumps, BD's w/ 0.008 EH tips, D2HP Inconel exhaust valves, D2HP custom pushrods, Custom HX50 bolted to Hmax pedistal, Suncoast Comp trans, Detriot Electrac's front and rear, D2HP transfer case and 1 piece 4" Al driveshaft.
Dave D's Truck: 2002 ECLB Built Ford Tough Package 6" DR lift kit, Bilstein 5100's, 36x15.50R20 MTZ's on 20x10 114 Eagle's, Randy Ellis Bar w/4 8" Stainless ProComp 130W Lights, Custom tunes from DP Tuner, 05 Harley front end, D2HP transfer case and 1 piece Al driveshaft.
Becky P's ride: 2002 Limited Excursion, DVD, heated seats, TS and DP tunes, Edge Juice & Attitude, Dual exhaust, Bilstein stock replacments, AFE.
D2HP is offline
post #3 of 4 (permalink) Old 02-19-2007, 04:08 PM
CSIPSD's Avatar
Yup, up pipes...
Name:	leaking up pipes2.JPG
ID:	8650   Click image for larger version
Name:	leaking up pipes again paint.JPG
CSIPSD is offline
post #4 of 4 (permalink) Old 02-19-2007, 05:35 PM
Diezel Dawg's Avatar
Yea just like the guys said above, it is your up pipes. I had the same problem with my truck and after tearing everything down when i replaced my Turbo, we decided to go ahead and do the donuts on mine. After we got the Y Pipe off, we noticed that one of the bolt holes was cracked, and after asking around, this is a common problem on the 7.3L. The two that i have seen with cracked bolt holes were both on the passenger side and it was on the back hole on both. You can get the Y Pipe at Ford for $94 or maybe $30 cheaper at International. The one you get from ford has the international number stamped on it, so of course they mark them up. Good luck, and if you take it off, USE a GOOD AMOUNT of PB Blaster on the bolts, they are a B**ch to get off. the bolt heads are 10MM
Ken
99.5 7.3L PSD 4x4
GTP38R BB TURBO
Casserly 250cc Hybrid injectors
BTS Trans W/ 6.0 Trans cooler
Live Tuned by Jody
TYMAR Intake/Coolant Filter
463hp and 912 tq 6 Feb 10
491hp 944tq 28 Aug 10
Future mods-- AirDog/ITP Reg Ret. Fuel sys. w/fuel bowl del, Terminator Big Oil,
PNWFDE#2
Diezel Dawg is offline
