Overdrive Question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by imported_99powerstroke, this thread has received 27 replies and been viewed 1030 times.
post #1 of 28 (permalink) Old 02-20-2007, 04:56 AM Thread Starter
Overdrive Question
I'm just wondering when I run my truck will it benefit me any running out of overdrive? I have heard to do it and then not to do it so thought I would ask
Thanks
imported_99powerstroke is offline
post #2 of 28 (permalink) Old 02-20-2007, 01:19 PM
TDG MAFIA #94
StrokinSnyd's Avatar
Send a message via MSN to StrokinSnyd
When your running out of overdrive, your rpms jump up, thus using more fuel. If your towing then kepping it out of overdrive helps since your engine is running at higher rpms. running it in overdrive lowers your rpms and thus gives you better milege. other than that, i dunno?
Others will surly chime in.
96 Dodge Cummins EC LB 5 spd big valve springs, full cut DV's, Big sticks, phat shaft turbo....yada yada yada.... plain and simple, it goes fast and pulls whatever
StrokinSnyd is offline
post #3 of 28 (permalink) Old 02-20-2007, 01:30 PM
The only time you really need to lock out O/D is when you are towing, and the tranny is shifting in and out of O/D constantly. Lock it out at that time to save wear and tear. Other than that, it's not necessary.
Pocket is offline
post #4 of 28 (permalink) Old 02-20-2007, 06:04 PM
I don't ever give mine overdrive until i hit 60, and when i'm slowing down i turn it off at 55.
Fast_Ashley is offline
post #5 of 28 (permalink) Old 02-20-2007, 07:40 PM
Thanks
What do you mean by run?
RacerX is offline
post #6 of 28 (permalink) Old 02-20-2007, 09:44 PM Thread Starter
sorry about the confusion.. I am talking about racing at the track or street
post #7 of 28 (permalink) Old 02-20-2007, 11:01 PM
Why?
gregrob is offline
post #8 of 28 (permalink) Old 02-21-2007, 12:19 AM
Because overdrive kills a 9,000 Lb. truck at 35 miles per hour, or at least kills the tranny.
post #9 of 28 (permalink) Old 02-21-2007, 01:01 AM
circle5's Avatar
i agree with fast ashley. i run mine the same way
circle5 is offline
post #10 of 28 (permalink) Old 02-21-2007, 01:16 AM
CSIPSD's Avatar
It wont hurt a thing to leave it in OD all the time. The only time it is helping anything is when it is hunting for a gear, shifting into and out of OD. I never lock mine out unless I am wanting some added exhaust braking or it is hunting when pulling. Your only wasting fuel to lock it out.
CSIPSD is offline
