No fuel - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Scooters99PSD, this thread has received 11 replies and been viewed 792 times.
post #1 of 12 (permalink) Old 02-20-2007, 06:47 PM Thread Starter
No fuel
Tried to start my 99 F350 yesterday. Started and ran about 2 mins. Changed fuel filter. Tried to restart nothing just rolled over. pulled out fuel filter nothing no fuel. Could the fuel pump went out? Thanks for any help.
Scooters99PSD is offline
post #2 of 12 (permalink) Old 02-20-2007, 07:34 PM
soot junkie
It sounds like the pump went out. Put your filter back in and have someone switch the truck on. Listen carefully to the cap and see if you hear fuel circulating. If not check your fuses and make sure it is getting power to the pump. If all that checks out then the pump is more than likely bad.
01 F350 CC Dually, DP tuner, fuel system w/Aeromotive pump, 360cc Stage III Hybrids, Stealth Big Oil, H2 Hybrid, Head Studs, Hypermax rods, balanced rotating assembly, Comp Cams valve springs and push rods, ATS trans fixed by BTS, Best 1/4 [email protected] best 1/8 [email protected]
2000 F250 6sp, Dp Tuner
Early 99 F350 2wd daily driver Dp Tuner
smokin dually is offline
post #3 of 12 (permalink) Old 02-20-2007, 07:55 PM Thread Starter
How hard is it to change?
post #4 of 12 (permalink) Old 02-20-2007, 08:00 PM
Super easy to change. I would try to test fuel pressure before you drop almost 200 on a pump.
Is it cold? Mine did this when it gelled and was exactly like the pump dying. I thought it did hurt the pump, but when I got rid of that trashy fuel, the pump is fine.
gregrob is offline
post #5 of 12 (permalink) Old 02-20-2007, 08:05 PM Thread Starter
Temps are around 40 and ipushed it in the barn last night. Listened down bye the frame rail, no sound. Which fuse do I check?
post #6 of 12 (permalink) Old 02-21-2007, 01:46 AM
soot junkie
I'm not sure of the number of the fuse. It should be in your owners manual. Also check the pump shut off switch in the passenger side kick panel.
post #7 of 12 (permalink) Old 02-23-2007, 10:02 PM Thread Starter
Replaced the fuel pump after all the air bleed out. It started and ran fine. took it for a test drive it still had a little shudder. I thought it still had some air in the fuel lines so a little wot. It sucked all of the fuel out of the bowl and now it won't start. I can hear the pump run. Is there a pump in the tank or is the sock pluged up. Thanks for any info.
post #8 of 12 (permalink) Old 02-23-2007, 10:38 PM
There is only 1 pump which is on the frame. More than likely you have something clogging the pickup tube in the tank. Could also be some crap plugging the fuel line between the pump and the filter though.
Eric
Dually Club Member #53
racehauler is offline
post #9 of 12 (permalink) Old 02-23-2007, 10:41 PM Thread Starter
How about blowing some air thru it each way from the pump?
post #10 of 12 (permalink) Old 02-24-2007, 03:08 AM
How much fuel is in the tank?
There is the premix valve slash prefilter in the tank that maybe clogged.
kainers is offline
