For how often they break, they should be easier to work on!!! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by sstockton, this thread has received 12 replies and been viewed 1025 times.
post #1 of 13 (permalink) Old 02-21-2007, 12:01 AM Thread Starter
Sorry for the long title. Well, my brothers ford has been down for quite a while, and finally he decided to try replacing the glow plugs, they have 180k on them, and some don't want to come out. Do you have any good tips on removing them. One of them everything except the "Probe" came out. Please don't take the title as being an insult, I'm just frustrated with the amount of time I've spent working on these trucks compared to my dodges.
post #2 of 13 (permalink) Old 02-21-2007, 12:12 AM
Got Diesel's Avatar
Huh, I don't know what to tell you. My glowplugs changed out really easy. As for the one with the broken off probe. Maybe try drilling the probe going really slow, and maybe then use a screw extractor. Dont' take my word on this. I am sure they have broken off before so let someone who has had to remove a broken one come along and tell you what to do.
They aren't that hard to work on.
Kyle
Early 99 F-250SD 7.3 PSD 4x4. Auto, tymar type intake, straight pipe, Six inch stacks, Tony Wildman Four position chip, Street race, 80 Tow, 80 Econo, Extreme. Let the smoke roll. Upgraded torque converter. Autometer Ultralights on the Pillar. Running Cooper Discover STT's.
Got Diesel is offline
post #3 of 13 (permalink) Old 02-21-2007, 12:51 AM
Diesel Dog's Avatar
Well aren't you just spoiled. :
I'd be pulling that head to make sure you don't drop any unwanted parts in there. But thats just me.
Diesel Dog is offline
post #4 of 13 (permalink) Old 02-21-2007, 01:03 AM Thread Starter
yeah, I kinda like the head pulling idea, except just seems time consuming. How Hard is it to pull the head on one of these, I've never done it. I will say that it looks way easier to pull a PSD head than the Cummins head thats for sure.
post #5 of 13 (permalink) Old 02-21-2007, 01:22 AM
Diesel Dog's Avatar
It's a piece of cake out of the truck. I've never pulled one in the truck, but I think it could be done and not be too bad.
post #6 of 13 (permalink) Old 02-21-2007, 01:23 AM
CSIPSD's Avatar
Not bad... Pull motor, remove head... Not bad at all... Or jack cab up, remove head... again not bad...
CSIPSD is offline
post #7 of 13 (permalink) Old 02-21-2007, 05:08 AM Thread Starter
Um damn... Well thanks, I think we'll try another route then and make this a last ditch effort. My theory on what has happened is that the end is too carboned up and can't easily pass through the hole any more. I personally don't like the thought of that at all, and it makes me wonder if there is now carbon in the combustion chambers of the other cylinders because it broke off when being pulled out.
post #8 of 13 (permalink) Old 02-21-2007, 06:15 PM
gregrob is offline
post #9 of 13 (permalink) Old 02-21-2007, 08:18 PM
mrector's Avatar
My brother(NMR 93) has a 96, and we ended up putting a body lift on the truck to clear to big turbo. This has aided him in being able to remove the heads w/out removing the engine. So maybe just put on a 3" body lift:Thumbup: then do it
Mikey
89 w250 project truck
mrector is offline
post #10 of 13 (permalink) Old 02-21-2007, 08:46 PM
I be Architect'n
We run into this alot on the old IDI engines, if you can still get ahold of them with needle nose vice grips, spray PB Blaster on it, wait 10 min's repeat, wait 10 min. and repeat. Then try to twist the plug. If it moves, keep twisting and pulling up and it might come out. I had to do this on my 93.
I wouldn't worry about the carbon bits too much, the combustion chamber is much bigger on a PSD than an IDI and mine passed fine. The threads on my glow plug actually pulled off of the probe part. The probe was just sitting there, stuck in the engine.
Also, excuse my ignorance if this won't work on a PSD, I've never changed my GP's but probably should.
2K3 EXCURSION 7.3L 4x4 EDDIE BAUER 107K miles as of 06-13-07
AFE Stage II / 4" MBRP exhaust / DP-Tuner F5 (Stock, 60hp Tow, 80hp Econo, 120hp race & High Idle) / Quadzilla Commander/ATS Housing
Running homebrewed BioDiesel and custom SVO kit for 70k miles.:Thumbup:
Misc. Mods: ZooDad/By-Pass Oil Filter/203* T-Stat/Coolant Filter/HPX/CCV Reroute/Tranny Filter/Foil Delete/Stereo Stuff/ITP Reg Return/Non-EBPV Pedistal and Exhaust Housing/Adjustable Waste Gate Controller/
"If you love your motorcycle, set it free. If it comes back to you it was probably a high-side."
I'LL TRY TO KEEP UP, BUT THE EXCURSION IS A BIG GIRL AND BIG GIRLS DON'T LIKE TO MOVE FAST.
6_Myles is offline
