*Fuel leak on 99 need fixed quick* - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by pwrstroke99, this thread has received 6 replies and been viewed 506 times.
post #1 of 7 (permalink) Old 02-21-2007, 12:02 AM Thread Starter
i replaced the fuel drain orings that still didnt fix it and i looked at the filter cap gasket and it is good idk what else, it leaks bad and i want to run my truck at the track friday night. please help
pwrstroke99 is offline
post #2 of 7 (permalink) Old 02-21-2007, 12:07 AM
Got Diesel's Avatar
I would say you have a cracked fuel filter housing. Pull the housing off the truck. Plug all the holes but one. Insert air here. Regulate to about 70PSI and you will find your leak.
Kyle
Early 99 F-250SD 7.3 PSD 4x4. Auto, tymar type intake, straight pipe, Six inch stacks, Tony Wildman Four position chip, Street race, 80 Tow, 80 Econo, Extreme. Let the smoke roll. Upgraded torque converter. Autometer Ultralights on the Pillar. Running Cooper Discover STT's.
Got Diesel is offline
post #3 of 7 (permalink) Old 02-21-2007, 12:22 AM Thread Starter
good idea thanks alot ill try that tommorrow after work and ill let u know how i make out
post #4 of 7 (permalink) Old 02-21-2007, 12:36 AM
moose99psd's Avatar
hold on before u go doing that... did u try to change the entire valve? when mine started leaking from there it was the entire valve not the orings
moose99psd is offline
post #5 of 7 (permalink) Old 02-21-2007, 12:47 AM
Got Diesel's Avatar
Good idea there nick. Didn't see that just did the o-rings. If the valve is leaking you will find it the way I mentioned. It's just a little more work. Not tons but a little.
Kyle
post #6 of 7 (permalink) Old 02-22-2007, 11:39 AM Thread Starter
it was the fuel heater leaking i already put new orings in it so i guess i had it to tight so i loosened it up and it stoped leaking thank god
post #7 of 7 (permalink) Old 02-22-2007, 08:51 PM
Man, I was about to ask you how tight did you tighten it. It plastic, but has metal inserts, and needs to be hand tight other wise you risk flexing or even damaging the assembly.
dfuser is offline
