Still Fight it - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Andy, this thread has received 12 replies and been viewed 892 times.
post #1 of 13 (permalink) Old 02-21-2007, 03:20 AM Thread Starter
Still Fight it
i have a 97 that i have done many upgrades. i put 230 injectors in it and it skips now. it's not an injecotor i tested them. did cct, and buzz test and passed. but still skips. changed wiring uvc and gasket still skips could it be a irp icp sensor or in my pcm oh yeah changed idm and wasn't that. what are theses fuel screens people are taking about. do you think it could be a fuel problem. i have just tried everything and getting very tired of fighting it. could it be the HPOP i know that is weak but could that cause it. i just need help fast anything will help. thanks andy
Andy is offline
post #2 of 13 (permalink) Old 02-21-2007, 03:57 AM
Codes? Hopefully you didn't just throw all that stuff at it guessing??? :shrug:
gregrob is offline
post #3 of 13 (permalink) Old 02-21-2007, 03:59 AM
pontiacross's Avatar
How long have you had your injectors. I just put mine in last week and its still idleing ruff, but I dont have a lot of miles on it yet I have been told by a couple of people it might take a while for it to smooth out. I would think if it was a hpop problem it would be cutting out at full throttle when you need the most oil, unless its getting air in the oil. Dose it start OK?
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #4 of 13 (permalink) Old 02-21-2007, 03:55 PM Thread Starter
There are no codes, the only one that i have ever got is the HPOP higher or lower then desired. but the injectors have been in it for awhile i have ran it it and dosn't seem to get better the only thing that seemed to improve it was a IDM that was worked so it put out 140 volts.
Andy is offline
post #5 of 13 (permalink) Old 02-21-2007, 05:58 PM
What kind of code scanner are you using?
gregrob is offline
post #6 of 13 (permalink) Old 02-21-2007, 10:59 PM Thread Starter
I'm using a Snap On, why does it matter. there is no code appearing that would contribute to this proplem. I guess i will jsut have to figure it out.
Andy is offline
post #7 of 13 (permalink) Old 02-21-2007, 11:10 PM
Well, first of all it matters because not all scanners will read codes from our trucks at all, some scanners will only read hard codes.
It matters second of all because you need to be able to do some live data logging to help figure out your problem.
gregrob is offline
post #8 of 13 (permalink) Old 02-21-2007, 11:15 PM Thread Starter
yeah i have done all the live data logging that the snap on will allow me and everything falls into spec is there something out there that can do more than the Snap on
Andy is offline
post #9 of 13 (permalink) Old 02-21-2007, 11:15 PM
Send a message via AIM to 250stroke Send a message via MSN to 250stroke Send a message via Yahoo to 250stroke
You still have the 10k mod on there ? if so id try pulling that and the chip at seperate times to see if theres any difference.
2004 F-250 Crew-cab XL 2wd 83000 miles . 4" straight pipe.
10/97 F-250, 180k on the clock, 4.10 gears, Autometer gauges,DIY intake, 3.5" down pipe to 4" straight , ATS 6 position chip, 37" BFG Baja T/A's and 24 bolt Hummer H1 wheels. 1 ton axles and custom suspension.
250stroke is offline
post #10 of 13 (permalink) Old 02-21-2007, 11:18 PM Thread Starter
the 10k is totally taken out and the chip is out for right know because i thought i got some ****ty burns so i sent it to E-Lite and they burned it. but it still runs the same with everythign out
Andy is offline
