fass or airdog? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by puredieselpower, this thread has received 12 replies and been viewed 2471 times.
post #1 of 13 (permalink) Old 02-22-2007, 12:39 AM Thread Starter
fass or airdog?
what are the benefits of each? Which is better? What do most do with the stock fuel filter?
Thanks
puredieselpower is offline
post #2 of 13 (permalink) Old 02-22-2007, 02:17 AM
I think you can build a complete system for less; regulated return and all. I'll have pics soon of my home brew fuel system. Just wrapping things up with the final parts I got today. I took out the fuel bowl and all quick connect fittings from tank to engine this past weekend. I did use kinda expensive Aeroquip fittings, but they sure do look cool. I ended up using Aeroquip 6AN socketless hose since it was cheaper than going to Napa for fuel injection hose by about $3per foot.
Tim -pics coming soon
Early 99 Crew Cab Long Bed Lariat 4x4 7.3L PSD Primary Horse Hauling Rig
-Stage 1 160cc Single Shot Injectors - DP Tuner F5 - 60 Tow, 80 Econo, High Idle, Stock - NVK5 PCM thanks to DP Tuner
-Home Brew fuel system with Aeroquip socketless fittings, socketless hose, and Aeromotive Regulated Return
-4" Lift 285/75R16 E Nitto Dura Grapplers - 5" MKO Aluminized Exhaust w/6" Stainless Tip - Pair of Optima Red Tops - Napa 6637 Air Intake filter - Triple Gauge A-pillar Pod w/Autometer UltraLite:Trans, EGT, Boost - CCV Mod
ndrorydr is offline
post #3 of 13 (permalink) Old 02-22-2007, 02:21 AM
Can't wait to see the pics!!
Fast_Ashley is offline
post #4 of 13 (permalink) Old 02-22-2007, 03:41 AM
TDG Mafia - Booze Runner
Snowaholic's Avatar
IMO FASS is a little better. They have revised and upgraded the pump, plus I believe that the FASS has a little better filtration. Airdog, came about after the father/son company of FASS split, and the Father started Airdog to compete with FASS. I will be in the market for a new fuel system in the next couple of months. For me it will be between FASS and GDP for my Cummins…..
2007 Dodge 3500 MegaCab Laramie CTD 4x4 Patroit Blue Just a bunch of Go fast parts and programing
Snowaholic is offline
post #5 of 13 (permalink) Old 02-22-2007, 04:54 AM
The Fass and Air Dog systems will replace fuel pump and filters only. They do not have a "regulated return" from the engine. IIRC both require a 5/8" feed from the tank and a 1/2" return to the tank. Then it has a 1/2" or 3/8" pressure line that goes to the engine.
I read through the instructions for the FASS once and I don't remember it saying anything about eliminating the stock filter. Probably would be best to call tech support about that.
As for which is the best - I have no clue. They appear pretty similar though.
Eric
Dually Club Member #53
racehauler is offline
post #6 of 13 (permalink) Old 02-22-2007, 05:25 AM
dzljon's Avatar
The FASS and airdog are designed by a Father and son, the Airdog is designed by the dad and FASS by the son, and there is some serious bad blood between them, the FASS has a reputation for poor machineing but that is only hearsay from guys with experience with them but the air dog has no bad press that i can find and all the guys i know that have it wont use nothing else. both ar designed to augment the factory pump, factory lift pump, filter and remaining components stay in place.
99.5 F250, VGT 5.9 CR cummins
dzljon is offline
post #7 of 13 (permalink) Old 02-22-2007, 05:32 AM
<img src="http://static.verticalscope.com/images/vb/badges/vendorBadge.gif" border="0" />
Strictly Diesel's Avatar
I'm not sure that's entirely accurate. The AirDog was developed specifically for the light duty diesel trucks. If Pureflow (then Ekstam Worldwide) simply wanted to compete with FASS, they would have just marketed the original FP-135 to the light duty market and made an install kit for it. Instead of doing that (the FP-135 is huge), they designed a physically smaller unit for our trucks and the AirDog was born.
Dennis Schroeder - Co-Owner of Strictly Diesel
Strictly Diesel Webstore / [email protected]
LIKE US on FACEBOOK! / Check Us Out on YOUTUBE!
Race Truck :: 6050# / 11.31 @ 120mph / Best 60' of 1.56 ... with "Built" Race Engine (Fuel Only!)
Race Truck :: 5980# / 10.965 @ 124mph / Best 60' of 1.54 ... with "Built" Race Engine (Nitrous)
Strictly Diesel is offline
post #8 of 13 (permalink) Old 02-22-2007, 05:35 AM
Just to clarify, the AirDog will NOT replace the stock pump. The AirDog is a HIGH VOLUME / LOW PRESSURE pump only. Current max output is 15psi (Dodge and maybe DMax configuration...standard Ford configuration is 10psi output).
Also, the AirDog is quite content working with the stock 3/8" pickup in the tank unless you need to use it to feed a larger aftermarket pump.
post #9 of 13 (permalink) Old 02-24-2007, 12:16 AM Thread Starter
So it will add 10psi to the stock pump?
post #10 of 13 (permalink) Old 02-24-2007, 01:08 AM
TDG Mafia Member # 37
01blkf250's Avatar
I believe Dennis is saying it will only put out 10 psi but will provide a good volume of fuel. Gene, :mafia
2001 F-250 XLT, cc sb 4X4, 3.73 LS,auto, Ported ATS shroud housing 1.00 exhaust housing Banks wicked wheel adjustable wastegated turbo,Non Ebpv pedestal and gutted Ebpv, DI Performance regulated fuel return kit, Dieselsites' 203* thermostat and billet housing, MBRP 4" ss turbo back exhaust system, AFE Stage 1 air intake, Jody Tiptons' F5 chip with no start,stock, 60hp tow,and 120hp race tune for now til I get big oil and injectors. Sonnax kit, Dieselsites' A/C heater core bypass valve, Autometer Boost, Pyro, and Trans temp guages in A pillar, Regulator in MAP line set at 20psi, boost tube, wastgate adjusted real tight, Aih delete, and Zoodad'ed. Amsoil fluids, Monroe Reflex shocks, and Ironman APR 265/75/16R tires.
01blkf250 is offline
