97 psd egt probe hole - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by pitjeep, this thread has received 11 replies and been viewed 4793 times.
post #1 of 12 (permalink) Old 02-23-2007, 01:43 AM Thread Starter
anyone have pics of where to drill & tap hole for egt probe on a 97 7.3?
pitjeep is offline
post #2 of 12 (permalink) Old 02-23-2007, 02:28 AM
pontiacross's Avatar
dont have any pics but I put mine on the driverside exaust manifold in the curve right before the up pipe. The probe is pointed down. I had plenty of room to drill it.
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #3 of 12 (permalink) Old 02-23-2007, 04:55 AM
yup go there, drivers side manifold right where it bends to the uppipe just as he said
DBogo is offline
post #4 of 12 (permalink) Old 02-23-2007, 05:23 AM
CSIPSD's Avatar
See Pic... This is a drill and clamp, but for the drill and tap, just hit the manifold.
CSIPSD is offline
post #5 of 12 (permalink) Old 02-23-2007, 10:56 AM Thread Starter
so if i want to tap it i should drill the manifold itself, about 4 to 6 inches to the right on your pic?
pitjeep is offline
post #6 of 12 (permalink) Old 02-23-2007, 12:41 PM
Yup!
1994 F-250 PSD ext cab 5spd 4x4 Gutted ebpv ,Valeo smf and clutch,3 pos Tony Wildman chip!, 3-4" Dp, 4" exhaust,Tymar intake, shimmed fpr, HPX crossover, 1.0 a/r exhaust housing, vdo gauges, 279,000k
1996 F-250 PSD CC SB 4x4, 5spd, 4:10's SMF clutch, 3" dp, cats gone, gauges Tymar intake, HPX, .84 a/r exhaut housing, 6oh intercooler/GTS kit, 4pos chip by Tony Wildman!
ltfox is offline
post #7 of 12 (permalink) Old 02-23-2007, 03:10 PM
ok i may be wrong but is this pic taken from the underside looking up?? if so the probe is pointed up???
just visiting is offline
post #8 of 12 (permalink) Old 02-23-2007, 03:53 PM
CSIPSD's Avatar
Yes and yes.
CSIPSD is offline
post #9 of 12 (permalink) Old 02-23-2007, 06:45 PM
Found On Russ' Drive
Russ's Avatar
I put mine in from the top. Drivers side manifold, hold your drill beside the master cylinder pointing down.
Duct tape... turning No No No into mmmmmm mmmmmmm mmmmmmm
Stormtrooper::1997 F-350 CC SRW PSD XLT 4X4: 332 hp 660 tq. made with Baby Swamps, Wildman 4 pos chip, 120V IDM, CCV mod, shimmed FPR, BTS E4OD, Baldwin air filter,triple pillar pod with Isspro gauges, 4" MBRP exhaust, SD dual tensioner mod, diamond cut headlights,Recon LED tailgate lights Hadley air horns,
Russ is offline
post #10 of 12 (permalink) Old 02-23-2007, 06:54 PM
CSIPSD's Avatar
Why? That is a very difficult area to get too, your not getting any better reading there, and the drill shavings are going to fall into the manifold rather then into your eyes...
From below you can see everything, and then you can run the wires thru the Auto tranny cable gromet... Very easy...:Thumbup:
CSIPSD is offline
