Got some numbers: - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 01blkf250, this thread has received 10 replies and been viewed 932 times.
post #1 of 11 (permalink) Old 02-24-2007, 01:02 AM Thread Starter
TDG Mafia Member # 37
01blkf250's Avatar
Got some numbers:
Okay the readings I had pulling the trailer were at the highest pushing 20 lbs.of boost and excelerating quickly but not by any means full throttle, were 24% duty cycle and 2794 on the inj. pressure. Cruising I was showing between 17 - 20% duty cycle and 700 and 900 inj. pressure at 60 mph, while boost was 3-4 lbs. Do these #'s indicate a fairly healthy HPOP. I can get some full throttle readings unloaded if need be. I figured that I would post the numbers here as nobody was responding in my post "Where is my IPR?". Gene :mafia
2001 F-250 XLT, cc sb 4X4, 3.73 LS,auto, Ported ATS shroud housing 1.00 exhaust housing Banks wicked wheel adjustable wastegated turbo,Non Ebpv pedestal and gutted Ebpv, DI Performance regulated fuel return kit, Dieselsites' 203* thermostat and billet housing, MBRP 4" ss turbo back exhaust system, AFE Stage 1 air intake, Jody Tiptons' F5 chip with no start,stock, 60hp tow,and 120hp race tune for now til I get big oil and injectors. Sonnax kit, Dieselsites' A/C heater core bypass valve, Autometer Boost, Pyro, and Trans temp guages in A pillar, Regulator in MAP line set at 20psi, boost tube, wastgate adjusted real tight, Aih delete, and Zoodad'ed. Amsoil fluids, Monroe Reflex shocks, and Ironman APR 265/75/16R tires.
01blkf250 is offline
post #2 of 11 (permalink) Old 02-24-2007, 01:22 AM
KRP
You need to do some long, hard, WOT runs to get a better idea of the condition of the HPO system. Are you throwing codes or losing power or something that is causing you to worry?
KRP is offline
post #3 of 11 (permalink) Old 02-24-2007, 03:06 AM
4cstr
Gene...with nearly 2800 psi oil...I think you are ok. When my hpop was going out...I could barely make 1300 psi.
post #4 of 11 (permalink) Old 02-24-2007, 01:48 PM
Diesel Dog's Avatar
I agree with Dave, But because it is working well today dosen't mean it will tomorrow. Mine worked great last April at Smokin and till Sept. it was tuckered out.
But I fixed that. :
Diesel Dog is offline
post #5 of 11 (permalink) Old 02-24-2007, 02:28 PM Thread Starter
01blkf250's Avatar
Not anymore but I was the guy that had codes 1209,1211,1212,1247,&1248, a couple of weeks back and could not get my truck to run for more than a few seconds at a time. I replaced my IPR and was just trying to determine if everything looks copacetic now. I'm paranoid I guess. Gene, :mafia
post #6 of 11 (permalink) Old 02-24-2007, 02:31 PM Thread Starter
01blkf250's Avatar
Ok thanks guys, like I said above I guess I'm just kind of paranoid. Gene :mafia
post #7 of 11 (permalink) Old 02-25-2007, 07:34 AM
You know nothing about the HPOP's condition if you didn't go WOT.
Go WOT in your highest setting and HOLD it there for a bit and record your lowest reading.
.02
gregrob is offline
post #8 of 11 (permalink) Old 02-25-2007, 03:11 PM Thread Starter
01blkf250's Avatar
Gregrob, I'll have to wait until the roads clear up a bit for that. On just slightly wet pavement I can break the tires loose at 45-50 mph, don't want to risk it with the roads covered with snow, slush, or ice. But thanks for the info, I'm just gonna have to wait til they clear and dry up alittle. Gene :mafia
post #9 of 11 (permalink) Old 02-25-2007, 06:52 PM
TDG MAFIA MEMBER #71
POWER STROKE 99's Avatar
What kind of reader are you pulling the numbers with?
POWER STROKE 99 is offline
post #10 of 11 (permalink) Old 02-25-2007, 08:31 PM Thread Starter
01blkf250's Avatar
A Snap on Scanner. It belongs to a friend of mine. I looked at getting one for myself but the cost is quite prohibitive---try around $5000.00. He said I can borrow it any time I want. I tell ya though this scanner is the schizzle !!! Gene :mafia
