SP Diesel Stage 1 Micro - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by CSIPSD, this thread has received 16 replies and been viewed 1099 times.
post #1 of 17 (permalink) Old 03-01-2007, 05:11 AM Thread Starter
CSIPSD's Avatar
Been Testing one of these for a few weeks. Tie's into the ICP sensor like a 18k type mod.
Its got three settings and you can feel them as you drive down the road. I was somewhat doubtful it would work for a damn on my truck with the injectors and such. But IT DOES on the lower chip settings. On the higher settings I simply run out of HPO.
If your looking for an inexpensive mod that is easy to install and will give you a nice kick in the pants its worth it. I cant say that I would run out and get one but for a first time mod, it is very nice. I would doubt you need a EGT with this for most trucks (cant believe I just said that...)
CSIPSD is offline
post #2 of 17 (permalink) Old 03-01-2007, 05:20 AM
sorry for asking stupid question but what is it and what is the 18k type mod and what do they do? can you use them w/ other chips?
thanks
imported_99powerstroke is offline
post #3 of 17 (permalink) Old 03-01-2007, 05:23 AM
The "10K" and "18K" and "?K" mods are all variants of a resistor tied into the ICP sensor to increase ICP.
Basically tricks the computer into thinking ICP is lower than it actually is, so the computer increases IPR duty cycle to raise ICP to what it thinks is the correct level.
I'm not speaking for this module as SP Diesel may have it programmed to do more than just this, but that is the basics of how the "resistor" mods work.
gregrob is offline
post #4 of 17 (permalink) Old 03-01-2007, 05:31 AM Thread Starter
CSIPSD's Avatar
It is micro processer controled, It knows when you are not on the gas so it doesnt boost it, but when you get on it bang its right there.
CSIPSD is offline
post #5 of 17 (permalink) Old 03-01-2007, 05:32 AM
That's very cool.
I'd be willing to try one to try and crank my ICP.
gregrob is offline
post #6 of 17 (permalink) Old 03-01-2007, 05:43 AM Thread Starter
CSIPSD's Avatar
I was suprized. I will tell you it will throw a ICP code in two seconds on the higher chip settings but on the tow and daily settings I have to work it and on stage 3 (of the micro) to get one.
CSIPSD is offline
post #7 of 17 (permalink) Old 03-01-2007, 05:44 AM
so there would be no problems using it w/ a chip??
nevermind just seen your post
post #8 of 17 (permalink) Old 03-01-2007, 05:48 AM
also what does ICP and IPR stand for???
post #9 of 17 (permalink) Old 03-01-2007, 05:58 AM Thread Starter
CSIPSD's Avatar
ICP= Injector control pressure
IPR= Injector pressure regulator
Yes its fine with a chip, would give a better kick with stock injectors too. I would LOVE to try it with Big oil!!! But it has to go back soon
CSIPSD is offline
post #10 of 17 (permalink) Old 03-01-2007, 08:47 AM
TDG MAFIA MEMBER #71
POWER STROKE 99's Avatar
What is the cost..........
POWER STROKE 99 is offline
