Early/late 99 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Fast_Ashley, this thread has received 13 replies and been viewed 770 times.
post #1 of 14 (permalink) Old 03-03-2007, 08:00 PM Thread Starter
Early/late 99
What's the cutoff date for early '99's??
Fast_Ashley is offline
post #2 of 14 (permalink) Old 03-03-2007, 08:14 PM
circle5's Avatar
i think its sometime in Jan 99 but not sure
circle5 is offline
post #3 of 14 (permalink) Old 03-03-2007, 08:32 PM
gregrob is offline
post #4 of 14 (permalink) Old 03-03-2007, 09:22 PM Thread Starter
Thanks Loco.
post #5 of 14 (permalink) Old 03-04-2007, 04:15 AM
dzljon's Avatar
i believe loco is wrong, 3/99 is when they did the change this the date shot at me when i buy parts mine just happened to roll off the line 3/99
99.5 F250, VGT 5.9 CR cummins
dzljon is offline
post #6 of 14 (permalink) Old 03-04-2007, 08:40 AM
Loco is not wrong.
gregrob is offline
post #7 of 14 (permalink) Old 03-04-2007, 05:05 PM
TDG MAFIA MEMBER #77
TooLoudTooBad's Avatar
What sticker are you getting the date from? I was changing my oil yesterday and cleaned the winter gunk off the pass side valve cover and seen a build date of 2/99.:shrug:
TooLoudTooBad is offline
post #8 of 14 (permalink) Old 03-04-2007, 05:55 PM
4cstr
If you have a build date that is in 99...then you have a late 99. Loco is not wrong. (Jeeze it pains me to say that. j/k Loco) The cutoff date was mid December 98. You can't go by door trim or fender badges, you need to look at the turbo and intake plenums. When the switch occurred...the larger turbo and larger intake plenums went in. And that occurred around mid December 98.
post #9 of 14 (permalink) Old 03-04-2007, 06:04 PM
Ol Dirt Contractor
Lowboy's Avatar
Loco is probably correct because our early 99 has a build date of 11/98.
I was Anti-Obama before it was cool!
Leno: ‘Remember the Old Days When Obama’s Biggest Embarrassment Was Joe Biden'
Ernie Hasse+ Bill Gaither America Medley
XCR 800cc Polaris Triple with Turbo, Nitrous & RMI
96 F250 7.3 Hypermax Stage III’s, H2 for now, Wide Open Performance long block. Spearco Intercooler 4” downpipe Suncoast Tranny, Terminator Oil
Newest--2015 Black VW Golf SportWagen TDI DSG Nav Roof 18" Avignon's Valentine One
Early 99 F250 SD 7.3 almost stock for now
87 Turbo Intercooled T-Bird stock
98 379 Pete 15.8L CAT 3406E 5DS Borg Warner 175963 Turbo P5 Nathan Horns Johnson Matthey 600 HP DPF 2017 CA registered emissions legal
More Milwaukee V28 Tools than Tim Allen has!
Remember, nozzle size matters at the pump
Lowboy is offline
post #10 of 14 (permalink) Old 03-04-2007, 07:12 PM Thread Starter
Don't mess with Loco!!
