HX mod - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by diesel_ram_man, this thread has received 3 replies and been viewed 447 times.
post #1 of 4 (permalink) Old 03-05-2007, 01:06 AM Thread Starter
diesel_ram_man's Avatar
Images: 6
HX mod
what is it? and what does it help?
The Diesel Garage.com
Can You Keep Up??
diesel_ram_man is offline
post #2 of 4 (permalink) Old 03-05-2007, 01:19 AM
Its a high pressure oil crossover line it helps equalize oil pressure between each of side of the motor it helps with a little quicker start up, smoother idle but no real performance gain...
03f3507.3 is offline
post #3 of 4 (permalink) Old 03-05-2007, 06:13 AM
TDG MAFIA MEMBER #77
TooLoudTooBad's Avatar
Check this out ----> http://www.dieselsite.com/index.asp?...PROD&ProdID=50
TooLoudTooBad is offline
post #4 of 4 (permalink) Old 03-05-2007, 09:51 AM
TDG MAFIA MEMBER #71
POWER STROKE 99's Avatar
ITP diesel sales them also. They sale the rigid line instead of the braided hose. The rigid line would probably be more reliable than the hose. Their was a thread on this a few day ago.
POWER STROKE 99 is offline
