I HAVE A 95 PSD AND I JUST PUT NEW STARTER SELINOID ON AND NEW STARTER AND SELINOID ON FENDER AND WHEN I GO TO START IT JUST CLICKS ONE TIME BUT WHEN I ARCH THE STARTER IT WILL TURN OVER WHAT COULD BE THE PROBLEM I EVEN PUT NEW BAT CABLES ON ?:shrug:
Low batterys? they need a lot of juice to fire the injectors, glowplugs and to run the computer... 90% of no start issues on a PSD are dead/low batterys
Could be that you have the wires hooked up wrong on your solenoid or maybe you got a bad one, or you have a bad connection at a battery cable. Clean the battery posts real good. Usually if it clicks once then nothing it's a bad connection.
i charged the batterys and check connections still nothing?
what is the ignition switch? and were is it at? thanks for youre input ill check again see if i missed anything.
:Thumbup: :bow: okay so i checked the connections again and i had a wire broke LOL
THANKS ALOT GUYS I WASTED ALL THAT MONEY ON NOTHINGointlaugh THANKS AGAIN:thanks: NOW I CAN BLOW SOME SMOKE:smoke
Related Threads
The Diesel Garage
1.2M posts
57.2K members
Since 2005
