Stopped running in traffic. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by AllOut0606, this thread has received 11 replies and been viewed 1063 times.
post #1 of 12 (permalink) Old 03-20-2007, 04:15 AM Thread Starter
TDG Mafia Member # 70
Send a message via AIM to AllOut0606
I went inside a store, came out, and the truck wouldnt start. it was about 60 degrees and the engine was hot. i cranked it over a few times in a row. nothing happened. i did notice tho: it had oil pressure as i turned it over, the rpms were going up and down, like they are supposed to, and i had fuel. then i let it sit a min and it started. a few miles down the road it stalled at a stop sign. i went through the same process. when i got it home i changed the fuel filter and cleaned all that out. as i was about to test drive it, i took off the emergency brake(while running), and it started to stall, but stopped. i applied and released the brake a few more times to verify it was constantly doing that. so i took out the ecu, and resecured it. i was holding it in half *** with zip ties instead of bolts, so i put bolts back in and cut some plastic so my big hoss would fit better. after everything was back in, i tested the e-brake, and the truck did not stall. could a loose ecu cause this problem? or how about if my big hoss was not making good connections? i ran it for a while tonight, starting stopping, etc. it hasnt stalled once. knock on wood. ;-) think i fixed it?
sorry this is so long.
2000 F250 7.3L CC Lariat 4X4 SB;
Performance:TS Performance Tuner///K&N Intake///Custom 5" Straight Pipe///6.0 Intercooler///B&M Trans Cooler///Foil Delete///Zoodad///CCV.
Interior: Autometer Gauges: Pyro, Trans, and Boost///Alpine In-Dash DVD Player///Audiobahn Sound System///Cobra 29 CB.
Exterior: Pro Comp 4" Lift///36" Super Swampers///16" wheels///Dual Hadley Peterbilt Horns///Viair 380c Compressor///Two 3 gallon air tanks///20% Tint///Warn Standard Hubs.
-Marshall-
AllOut0606 is offline
post #2 of 12 (permalink) Old 03-20-2007, 11:05 AM
Diesel Dog's Avatar
I'd say you fixed it. :Thumbup:
Diesel Dog is offline
post #3 of 12 (permalink) Old 03-20-2007, 02:07 PM Thread Starter
i sure as hell hope so.
-Marshall-
post #4 of 12 (permalink) Old 03-20-2007, 02:33 PM
Keep us posted:Thumbup:
Fast_Ashley is offline
post #5 of 12 (permalink) Old 03-20-2007, 04:25 PM
Could very well be a loose connection with the chip. Make sure it's in good and getting good contact and maybe even tape it in.
466 on #2 only
739 with NČO
13.544 in 1/4 mi!
Yeah I can keep up!:Thumbup:
gtspowerstroke is offline
post #6 of 12 (permalink) Old 03-20-2007, 04:50 PM
TDG MAFIA MEMBER #77
TooLoudTooBad's Avatar
If you tape it in, use clear shipping tape. Best thing out there for this application!:Thumbup:
TooLoudTooBad is offline
post #7 of 12 (permalink) Old 03-20-2007, 08:26 PM Thread Starter
i will keep everyone posted. i'm about to go to work, hopefully it wont let me down.
-Marshall-
post #8 of 12 (permalink) Old 03-21-2007, 05:21 AM Thread Starter
so far so good. a succesful trip to and from work. also went to get food with no problems.
-Marshall-
post #9 of 12 (permalink) Old 03-23-2007, 02:13 PM Thread Starter
i put my banks big hoss back in the truck. and it wouldnt start again. but as soon as i pulled it out. she fired right up. i am thinking that i did not clean the pcm port good enough, so conductors are making contact and some arent, or my big hoss is just f****d up.
-Marshall-
post #10 of 12 (permalink) Old 03-23-2007, 04:05 PM
Big hoss is probably junk. You just might have to get a new chip(the only upside is that the supporting vendors blow banks away as far as performance!) Does it throw any codes with the banks stuff on it?
