Glow Plugs - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Andy, this thread has received 4 replies and been viewed 653 times.
post #1 of 5 (permalink) Old 03-20-2007, 05:33 AM Thread Starter
Glow Plugs
How do you check the glow plugs in the truck. I know check with a multi meter but what to what for acurate reading. and what should i see for results.
Also how do you check the glow plug relay, i replaced the old one with one from NAPA but the angle of the new one was diffrent from the old one and the posts were not labeled. so how do i know i hooked it up right and test it to make sure the new one works right.
THANKS ALLOT GUYS JUST GOT A LITTLE CONFUSED, ANDY
Andy is offline
post #2 of 5 (permalink) Old 03-20-2007, 05:38 AM
I check them with a test light. Connect to pos. side of battery touch each plug if they are good it should light up as you touch the tip(gotta remove valve covers and the glow plug cap)
Fast_Ashley is offline
post #3 of 5 (permalink) Old 03-20-2007, 05:48 AM Thread Starter
Yeah i have the valve cover off and was trying to check them with a multi meter but wasn't sure if touching the tip and then a ground was the right wasy to do it. Also wasn't to sure what the readings whould be. thanks again Andy
Andy is offline
post #4 of 5 (permalink) Old 03-20-2007, 11:03 AM
Here you go.
Go the Articles and Information section and then under the Powerstroke 7.3L: How to check for a bad Glow Plugs and Relay
dfuser is offline
post #5 of 5 (permalink) Old 03-20-2007, 04:59 PM Thread Starter
Thanks allot this will help big time
Andy is offline
