Turbo problem - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by eng55marine, this thread has received 8 replies and been viewed 651 times.
post #1 of 9 (permalink) Old 03-26-2007, 07:48 PM Thread Starter
Turbo problem
Can anyone help me with these codes, P0238-Turbogharger boost sensor A circuit high, and P1249-Wastegate control valve perform. Just had the trans rebuilt and they also come up with these codes. Thanks, Art
My truck is a 2001 F350 4X4 7.3L. An AFE stageI, Banks big hoss bundle and an SCT tuner By Doug
eng55marine is offline
post #2 of 9 (permalink) Old 03-26-2007, 08:03 PM
0238- I think it's a faulty map sensor. Not sure about the other one.
Fast_Ashley is offline
post #3 of 9 (permalink) Old 03-26-2007, 08:25 PM
P0238 is a overboost code. Verry common on a modded truck if you dont have a regulator in the map line.
However it seems odd that you also got a code for the wastegate. Maybe the wastegate acutator isn't working properly. Do you have a Banks wastegate actuator? Do you have the wastegate wired shut?
Eric
Dually Club Member #53
racehauler is offline
post #4 of 9 (permalink) Old 03-26-2007, 11:32 PM Thread Starter
I do have the banks wastegate, I noticed the set nut came loose. I'll fix it tomorrow and see if that helps the problem. Will I have to get the codes cleared?
post #5 of 9 (permalink) Old 03-27-2007, 02:23 AM
Yep get the codes cleared. Dennis at ITP has a boost regulator, and it's the cat's meow!!
post #6 of 9 (permalink) Old 03-27-2007, 02:51 AM Thread Starter
Sorry for sounding stupid, what is a boost regulator
post #7 of 9 (permalink) Old 03-27-2007, 03:00 AM
Same thing as apressure regulator on your air compressor, except on your map line. Regulates the amount of compressed air your map sensor sees so it won't de-fuel. It de-fuels at like 20-23 Lbs. of boost pressure.
P.S. You can't ask a stupid question, my girlfriend handles that!!!
post #8 of 9 (permalink) Old 03-27-2007, 03:02 AM
It is a regulator that is put in the MAP hose that will keep the MAP Sensor from seeing more than 24 psi. The computer will de-fuel if boost gets above 25-26. With free flowing exhaust, intake, and a chip you will see more than 25 psi when you are running it hard.
Edit: fast_ashley beat me to it...your just too fast for me!!
Eric
post #9 of 9 (permalink) Old 03-27-2007, 03:08 AM
Edit: fast_ashley beat me to it...your just too fast for me!![/QUOTE]
That's why they call me fast_ashley My truck on the other hand is slower than *****!!! Wait til' everyone finds out, I'll be ruined
