blue international cps swap from dt466e - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by sidssm, this thread has received 19 replies and been viewed 5161 times.
post #1 of 20 (permalink) Old 04-17-2007, 07:56 AM Thread Starter
sidssm's Avatar
here is a sight selling this blue dt466e cam sensor it says it is better along with better performance here is the site http://www.puredieselpower.com/catal...sel-p-126.html
has anyone done this and if so did it help i would like everyones opinion on this thanks seth
sidssm is offline
post #2 of 20 (permalink) Old 04-17-2007, 08:21 AM
TDG Mafia Member #56
Dieselwrencher's Avatar
Oh what does that say in that description? I think I got my hands slapped for saying this a few weeks back in a different thread.
Works on all 99-03 7.3L Powerstroke Diesel
94-97 models may require shimming to install correctly.
I say try it appears to be in the same price range as the Ford ones.
Putco light bar
Dieselwrencher is offline
post #3 of 20 (permalink) Old 04-17-2007, 08:26 AM Thread Starter
sidssm's Avatar
which part did you get your hand slapped for did i do something inappropriate thanks seth
sidssm is offline
post #4 of 20 (permalink) Old 04-17-2007, 08:29 AM
No, you did not do anything wrong. . I just stated that if you use a IH brand cps in the ford 94-97 7.3 psd you may have to shim it for it to work properly and I was told no I was wrong shimming was not nesccesary. But it clearly states it in your post, so thank you for finding that info.
Putco light bar
post #5 of 20 (permalink) Old 04-17-2007, 08:32 AM Thread Starter
sidssm's Avatar
no problem i am new to this forum so i thought i had done a no no thanks
sidssm is offline
post #6 of 20 (permalink) Old 04-17-2007, 08:35 AM
No, you did just fine, by the way welcome to the diesel garage!
Putco light bar
post #7 of 20 (permalink) Old 04-17-2007, 02:27 PM
TDG Mafia Member # 37
01blkf250's Avatar
The blue sensor from the DT466 will work, it just has a tapered end so it picks up the signal from the cam a little later thereby retarding your timing alittle. Some dyno testing has been done and it was just a few horsepower lower than the 7.3 cps. The tapered end has a stronger magnet, and is said to be more vibration resistant. I am running one in my truck right now. I can honestly say that I did not notice the smoother operation or the better fuel economy that has been claimed with this cps, but if it last longer it's all good as I am on my fourth cps in just alittle over 100,000 miles. I believe they might be more durable and less prone to fail as they are made for otr trucks and you don't hear of them failing like you do our 7.3 cps'. Gene :mafia
2001 F-250 XLT, cc sb 4X4, 3.73 LS,auto, Ported ATS shroud housing 1.00 exhaust housing Banks wicked wheel adjustable wastegated turbo,Non Ebpv pedestal and gutted Ebpv, DI Performance regulated fuel return kit, Dieselsites' 203* thermostat and billet housing, MBRP 4" ss turbo back exhaust system, AFE Stage 1 air intake, Jody Tiptons' F5 chip with no start,stock, 60hp tow,and 120hp race tune for now til I get big oil and injectors. Sonnax kit, Dieselsites' A/C heater core bypass valve, Autometer Boost, Pyro, and Trans temp guages in A pillar, Regulator in MAP line set at 20psi, boost tube, wastgate adjusted real tight, Aih delete, and Zoodad'ed. Amsoil fluids, Monroe Reflex shocks, and Ironman APR 265/75/16R tires.
01blkf250 is offline
post #8 of 20 (permalink) Old 04-17-2007, 03:28 PM Thread Starter
sidssm's Avatar
o1blk250 how will the retarded timing affect the 7.3
sidssm is offline
post #9 of 20 (permalink) Old 04-17-2007, 05:07 PM
01blkf250's Avatar
Doesn't hurt anything, but dyno testing has shown about 3-5 hp less. I personally am willing to give up some power if it last longer. Some guys have claimed better fuel economy and smoother operation, but as I said I honestly didn't notice either. Gene :mafia
post #10 of 20 (permalink) Old 04-17-2007, 05:27 PM
Some trucks will run much quieter with the blue one.
Shimming is only required on some early 94-96.5 and that was due to length of the later model CPS.
Check them out! We have them here on this link with free shipping!
Also, the 7.3L black one will work on the dt466e
dfuser is offline
