Fuel System - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by powerstrokin94, this thread has received 1 replies and been viewed 605 times.
post #1 of 2 (permalink) Old 05-02-2007, 04:24 PM Thread Starter
Fuel System
What kind of fuel system is recommended to run on my OBS? i have been looking into aeromotive but i was wondering on everybody's input. thanks
powerstrokin94 is offline
post #2 of 2 (permalink) Old 05-02-2007, 04:30 PM
Aeromotive has some good stuff. If you are not planning on larger injectors than you have now but want an electric pump the stock SD pump will work great. I have one on my truck with an Aeromotive regulator and it will not drop fuel pressure with my stage 1 injectors.
If you think you will be going to some big injectors someday then you might as well get the areomotive pump now instead of changing later.
Eric
Dually Club Member #53
racehauler is offline
