Killed the Turbo - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by imported_DieselKid, this thread has received 28 replies and been viewed 1326 times.
post #1 of 29 (permalink) Old 05-03-2007, 07:23 PM Thread Starter
Killed the Turbo
Me and a couple friends were pounding on our trucks 2 days ago and the turbo started making a pinging noise at 45lbs., then when I went to shut the truck off it sounded like a ton of marbles going through the motor. Pulled the turbo off and the thrust bearing had come apart and the wheel was hitting the housing. Got a new stock turbo on today (can't afford a better one yet). How long will this new stocker hold up at high boost numbers.
thanks
Robert
imported_DieselKid is offline
post #2 of 29 (permalink) Old 05-03-2007, 07:48 PM
You were pushing 45lbs on a stock turbo?!?!?! mg
I didn't even think that was possible. What were your egt's?
Pocket is offline
post #3 of 29 (permalink) Old 05-03-2007, 07:49 PM
A van turbo would hold up longer.
Check with Bean's, he has complete kits for probably less than you paid for that stocker.
Or get a drop-in TN from Black Widow for about $12-1300
BONE STOCK
444turbodiesel is offline
post #4 of 29 (permalink) Old 05-03-2007, 07:53 PM
plainredtruck's Avatar
Images: 11
Not long @ 45 psi
Turbo will feel like the poor guy under the boot :splat
I'll say 5 runs at that psi. MAX.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
post #5 of 29 (permalink) Old 05-03-2007, 08:36 PM
you need an h2e kit it will live at 45 psi
LIPD is offline
post #6 of 29 (permalink) Old 05-03-2007, 08:55 PM
CSIPSD's Avatar
thanks
Robert
Your killing your truck with Back pressure and high EGT's running that much Fuel and boost... Back it off a bit for a while until you can afford the right parts...
CSIPSD is offline
post #7 of 29 (permalink) Old 05-03-2007, 09:19 PM
Send a message via AIM to Powersmoker113
275 CC injectors with stock turbo!!!.......geez i thought my 180cc injectors on a stock turbo was bad enough. My egts are high too!
2000 PSD F250 Regular Cab. 221k miles, bb Garrett, Swamps Gen3, A1000 Pump, Complete fuel system, Mac Cold Air Intake, 230cc stage 3 single shots, big ol nozzles, Transmission Built from Twisted Diesel Performance, DPtuner, , 4 inch exhaust, 6 inch silverline Tip, Zoo-dad mod, t/c lockup switch, HX crossover line,Intake heater delete,3.73 w/ reworked limited slip, 4 inch hanger kit, 33x12.5 BFG m/ts , 16.5X12 C2's, 04 headlights, 05 grill.
Powersmoker113 is offline
post #8 of 29 (permalink) Old 05-03-2007, 10:06 PM
45?? I can't imagine why it came apart...
My new QSSB will run that but definately not a stocker.. How did you hold that much pressure? BBH cranked down?
Slated4Greatness is offline
post #9 of 29 (permalink) Old 05-03-2007, 10:22 PM
Chitowns Biggest Baller
6.4lkid's Avatar
His EGT suprisling are not that high.
Formerly 6.0lkid
2008 F250 FX4 Loaded
SCT TUNED
6.4lkid is offline
post #10 of 29 (permalink) Old 05-04-2007, 01:56 AM Thread Starter
I can barely hit 1600 degrees and it loves being at 45 lbs. and I only payed $200 for the turbo, should i adjust the wastegate actuator, which way do I go on adjusting it?
