01 7.3 Powerstroke no top end power - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by tim5374, this thread has received 13 replies and been viewed 8409 times.
post #1 of 14 (permalink) Old 08-17-2005, 10:40 PM Thread Starter
2001 F-350 7.3 Powerstroke 4x4 Auto
Ts Performace 6 stage chip.
Ran great for a while, now it seems the timing isin't advancing.
still have plenty of turbo boost & smoke but no difference in power between 3/4 & full throttle. :shrug:
tim5374 is offline
post #2 of 14 (permalink) Old 08-17-2005, 11:49 PM
Do you have a way to guage your hpo/icp?? scanner/pressure guage??
Why do you feel the timing has changed?
Just curious, how long has it been since you changed your oil?
Tim
Tim @ P.I.S. is offline
post #3 of 14 (permalink) Old 08-18-2005, 01:24 AM
4cstr
What type of intake on the truck. Stock...aftermarket...Tymar? How about exhaust? Any guages? We need to know a bit more about the truck.
post #4 of 14 (permalink) Old 08-18-2005, 02:04 AM
'Ol Builder guy
Duke's Avatar
Do the simple stuff first: Change oil & change fuel filter. Wouldn't hurt to see if your fuel pump is clogged with trash from your tank, too, or maybe weak and about to need replacement.
Duke is offline
post #5 of 14 (permalink) Old 08-18-2005, 04:32 AM
If boost is the same, your engine may not be the problem. You know stock turbo on this year has stall probs. at higher rpm that is fixed with a new wheel. I notice you have an automatic trans-do you think you may have convertor problems?
sniperonhigh is offline
post #6 of 14 (permalink) Old 08-27-2005, 10:10 PM Thread Starter
Thanks for all the sugestions.
I think we found the problem.
the oil was just changed, the Engine, intake & trubo all stock.
it just put a rod out the side of the block, so we pulled the heads and 1 of the injectors was plugged with some kind of melted plastic looking stuff.
Again thanks for the help & keep up the good work
ps. do you think the rod & injector problem could have been related ???
tim5374 is offline
post #7 of 14 (permalink) Old 08-27-2005, 10:23 PM
'Ol Builder guy
Duke's Avatar
Was the fouled injector the same hole with the piston that let go?
Duke is offline
post #8 of 14 (permalink) Old 08-27-2005, 10:26 PM
What setting was the chip on when it threw a rod. TS fuel7 has been known to do this.....but dont qoute me on that. :evil:
joediesle is offline
post #9 of 14 (permalink) Old 08-27-2005, 11:25 PM
Do you actually know someone this happened to??
Many people knock that program, but for a long time it was held as the highest power making program around.
Yes it is a bit noisy, it has a bit of timing in it, i know cause i have seen the tables on it. but timing makes power, its a give and take thing.
Anyways, i have never known ayone to vent there block with JUST running fuel 7, so easy on what you say, er type.
Tim
post #10 of 14 (permalink) Old 08-28-2005, 02:38 AM
'Ol Builder guy
Duke's Avatar
'Bout time you joined, brotha!!! :Thumbup:
Wasssupp???
Duke is offline
EGR / OIL cooler rebuild??????? Mike 2003-2007 6.0L Power Stroke 13 01-02-2009 04:59 AM
Stolen Husky 372xp Replacement ? BROKER The Parking Lot 12 08-07-2007 02:25 PM
performance video bbunting General Ford Truck and Excursion 14 09-05-2005 02:08 AM
TBS5...anyone?? alldiesels 2003-2007 6.0L Power Stroke 18 08-21-2005 06:49 AM
Need Help with Plug-in Tuners Paxamus 2003-2007 6.0L Power Stroke 4 08-19-2005 04:08 PM
