Water/meth tank above nozzles? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Cerebus, this thread has received 7 replies and been viewed 714 times.
post #1 of 8 (permalink) Old 05-10-2007, 02:02 PM Thread Starter
I've got a Snow kit and the instructions say if the tank is above the nozzles, you need a solenoid ...makes sense. Problem is I'm still wary about something going wrong and hydrolocking the engine. Does anyone have a setup where the tank higher and using a solenoid? Other experiences? TIA
2000 F250 PSD, XLT, SC, LB, 4x4, auto: Autometer Nexus gauges, DIY-Injectors.com Stage III Hybrid injectors, BTS Transmission, H2E Turbo, DP Tuner F5 (stk, HI, 60t, 80e, 120r), 4" MBRP, AFE Stage 2 PG7
Cerebus is offline
post #2 of 8 (permalink) Old 05-10-2007, 02:16 PM
6.0 powered
Yup you need the solenoid if the take is higher than the nozzles otherwise the water will just flow and you would hydro lock
Dave is offline
post #3 of 8 (permalink) Old 05-10-2007, 02:23 PM
CSIPSD's Avatar
To me, doesn't matter if the tank is high or low, put the solenoid in there and never worry. 70k with water meth and not one issue...
CSIPSD is offline
post #4 of 8 (permalink) Old 05-10-2007, 04:33 PM Thread Starter
That's actually one option I didn't think of ...the small added cost would be worth the piece of mind.
I guess my follow up question would be do I have to go with the solenoid Snow sells, or can I pick one up anywhere?
Cerebus is offline
post #5 of 8 (permalink) Old 05-10-2007, 04:39 PM
CSIPSD's Avatar
I would not buy anything from snows... I cant stand there company, or there CS after the sale... Once they have your money... there done.
Try www.coolingmist.com for parts, cheaper I bet too.
CSIPSD is offline
post #6 of 8 (permalink) Old 05-10-2007, 05:06 PM Thread Starter
http://www.coolingmist.com/detailmain.aspx?pid=11
That look right?
Cerebus is offline
post #7 of 8 (permalink) Old 05-10-2007, 05:16 PM
CSIPSD's Avatar
Yup, then hook that to the power supply on the pump, when the pump turns on the valve opens, when it stops the valve closes...
CSIPSD is offline
post #8 of 8 (permalink) Old 05-10-2007, 05:18 PM Thread Starter
Cool. Thanks!
Cerebus is offline
