pcm codes - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Hitechredneck, this thread has received 4 replies and been viewed 985 times.
post #1 of 5 (permalink) Old 05-12-2007, 03:28 PM Thread Starter
pcm codes
allright just bought a dp tuner i need to get it reflashed. well i have a 94 just pulled the pcm out to remove the banks big hoss. now the previous owner told me that the truck was reprogrammed as a 96 or 97. will this change my code. here the code i hve now BEG6. that is on the pcm. But on the chip is engraved my hand MLE1. does any of this make sense any input would be nice thanks
Hitechredneck is offline
post #2 of 5 (permalink) Old 05-12-2007, 04:26 PM
Since the DP-Tuner chips are all 4-bank chips (meaning they COMPLETELY disable the program in the PCM), it really doesn't matter what the original code is in the the PCM. So, despite the fact your PCM says BEG8 (a 94/95 calibration), the chip will run the MLE1 calibration stored on the chip which is the latest code for a 97 M/T truck. If the PCM is in fact reprogrammed, the only way to tell what it is programmed to is to actually read the PCM ID using a scan tool or some other such device to identify the calibration filename in the PCM. Again, this is a moot point when using a 4-bank chip.
Incidently, the 97 M/T and A/T codes are the best all-around calibrations to use. They provide the best overall drivability compared to earlier calibrations and respond very well when tuned for modifications such as turbos and injectors. The latest code for the M/T is MLE1 and the latest code for the A/T is TDE1, just in case anyone is curious.
Hope this helps.
Bill
ASEMechanic is offline
post #3 of 5 (permalink) Old 05-12-2007, 04:48 PM Thread Starter
Thanks alot. that helped everything. also the chip i bought is for an early 99 auto so i def. need to have it reprogrammed correct
post #4 of 5 (permalink) Old 05-12-2007, 04:57 PM
Most definitely. A 99 code will not work on a 97. Just give Diane a jingle and git 'r dun.
Take care.
Bill
post #5 of 5 (permalink) Old 05-12-2007, 05:24 PM Thread Starter
i was talking to her this morning
